El - Glo Dials
Wazz72
Just changed the dials again. Used a spoon to remove the temp, and fuel needles. put them back on where they were, put the dash back and turned on the ignition, and the bloody fuel gauge started to drop from just under 1/2 a tank to 0. does anybody know what this is, and how to get it back to 1/2 a tank. I know Supras drink fuel, but half a tank in 2 mins is a bit much seems I didn't even touch the accelerator.
I had this exact problem too, what a pain in the arse.
I got it working eventually but I don't know exactly how.
You've got to make sure the needle spindle isn't catching, I pulled off and fitted the needle loads of times until it worked correctly. Just trial and error really, fitting it with the ignition on and off.
Did you guys glue your dials down? I had problems as there was a big dollop of glue(someones previous repair or are they all like that?) around the stop pin on the speedo, which made the dial ride up & catch the needle. Well worth it tho, think they're a huge improvement on the originals.
you dont have to take the needles off to install the glow dials, but since you have you have probably put the needle back on wrong, as if you move the fuel gauge while doing this, when you apply power back on the gauge cluster the fuel gauge will correct itself, so you may have knocked it up, fitted the needle back on where you thought it was origanally, then cause its actually higher it will start to go down, the only thing you can do now, is fill up right to the top, take the needle off, switch the car on and leave it on for 5mins, (as the fuel gauge takes forever to read the fuel first time after fill up) the fit the needle back on so it pointing at the F, then it should be fine..
