EGT Gauge sensor mounting
Ark
OK, I've got a DEFI EGT gauge to install, and I want to mount the sensor in my downpipe (I know it would be 'better' placed in the manifold, but this is more accessible). Given that I have an un-blemished downpipe at home waiting for installation, I can kill two birds with one stone here...
Anyway, where can I get a mounting boss to weld to the pipe, so I can just screw the sensor straight in? It should be a 1/8PT size.
Thanks
I had a defi gauge positioned in the wrong place and the reading as a complete waste of time, it did look pretty though all lit up on in the dash but if you are going to spend that much on a gauge and fitting why not have it in the right place where it will tell you what your EGT are and if you have a problem, which is what it was designed for, mind has been changed now and does what it is supposed to, its worth the hassle ;)
Hmm, maybe I'll take it to the local motorsport garage who are also Defi dealers. Much as I'd like someone like CW to fit it, £200 of petrol to get £50 of work done doesn't make much sense...
New question then:
I want an AFR gauge too. Can this probe be mounted in the downpipe or is this another manifold jobby?
Of course if you fit it before the turbo you have the worry that when/if the probe tip breaks your turbo(s) will be knackered too.
If you fit it as close as poss after the turbo you don't have that problem.
Now this does keep coming up as the reason for not having an EGT sensor/gauge (having it after the turbo is the same as not having it...) but how many have self destructed in the last four or five years?
-Ian
New question then:
Nope, it's a middle of the centre section of the exhaust jobby :)
-Ian
New question then:
-Ian
And there's a handily placed grommet under the gear selector to run it through as well. :)
So you're saying that having that have an EGT probe mouted directly after the turbo gives you no useful indication of EGTs? Sorry but I don't believe it.
Temps post-turbo are lower than they are pre-turbo but one is still able to spot above normal EGTs with a post-turbo sensor, surely?
Isn't it just that the threshold for "Whoa! That's too hot" is at a lower temp than it would be with the probe mounted in a runner?
Dunno how many but I've heard of it happening. With my luck, I wouldn't want to risk it.
I agree with Ian. What you really want to measure are temps in the combustion chamber. This can be done, and is done by serious tuners and manufacturers, but it's VERY expensive, and usually done alongside real time cylinder chamber pressure wave measurements.
The further away from the chambers you probe the less accurate the results. Throw the dampening characteristics of a turbo into the equation and measurements after it are so time delayed and inaccurate as to be all but meaningless.
No, but the lag time is so signicant that by the time the raised temps are seen post turbo the piston ring lands will have probably already have collapsed. The turbos are massive heat absorbers, and act as thermal dampers. If you are happy post turbo fine, fit the thing post turbo, but it won't make it correct, or be much more than a dash ornament. :)
