will these fit?
Guest Phillw454
what do you adapt the indicators?? i dont like anything complicated:search:
The side lights on the early model Supras are in the headlights, so you will need to splice the wiring on the the feed to the headlights.
As said you will need to buy (or fabricate) 2 harnesses from Toyota, these are around £15 each.
