RedM Posted February 6, 2007 Share Posted February 6, 2007 I have a slow leak from the coolant drain hose. It's not the first time. http://www.mkivsupra.net/vbb/showthread.php?t=60621 Back then we just tightened the bleed screw thingy and it's been fine up until now. Does the little screw thing seem prone to leaking? I'm assuming it warms up and cools down and over time it must leak a little. Thoughts? Link to comment Share on other sites More sharing options...
TrickTT Posted February 6, 2007 Share Posted February 6, 2007 There is a couple of O-rings on the drain plug that have probably gone hard over time. Try replacing them, and wrap the thread it ptfe tape when you put it back Link to comment Share on other sites More sharing options...
