CJ Posted February 6, 2007 Share Posted February 6, 2007 I am looking for a radiator for an auto facelift NA and was wondering if the TT rad is the same as the NA ones? Then, if so, would a pre facelift rad fit a facelift model? Link to comment Share on other sites More sharing options...
imi Posted February 6, 2007 Share Posted February 6, 2007 With the TT, the facelift ones will fit the pre-face cars (albeit they are different rads) Link to comment Share on other sites More sharing options...
Jake Posted February 6, 2007 Share Posted February 6, 2007 I'm 95% sure a TT rad will fit an NA. I have a facelift TT auto rad in my 93 Auto RZ. It went in OK but the shroud didn't fit quite right (One bolt hole difference) Also the elec fan arrangement is different and the connectors didn't match so I just left the elec fans disconnected. Edit: No that's wrong - gimme a min to re-write it. Edit II: OK, IIRC the pre-facelift shroud is slightly different but seems sturdy enough with the one bolt missing. After a bit of trial and error I decided to use the old 93 shroud with the 98 Rad so that I could have working elec fans. Otherwise I'd have had a shroud that fitted but fans that didn't work. n.b. (by 'shroud' I'm talking about the plastic bit on the back of the rad that holds the elec fans) Link to comment Share on other sites More sharing options...
CJ Posted February 6, 2007 Author Share Posted February 6, 2007 Thanks for the info fella's Link to comment Share on other sites More sharing options...
