just a couple of quickies!!
gisalive
Hi fellas just wanting some recommendations on which and where to buy a new oil filter for my n/a supra, also steering is occasionally feeling a little heavy would this just be a fluid change is it easy to do any instructions would be greatfully recieved. Cheers
Oil Filter – I’d go for the Lexus V8 oil filter (part no. 90915-20004) they’re about £10. It’s a direct swap and it’s bigger so supposedly gives better filtration. Have a search on here for some info.
Power Steering – You say it sometimes goes heavy. Supra's have progressive power steering that gets heavier the faster you go. Maybe that’s the cause?.. Is your car speed delimited as this can affect the way the progressive power steering works if not done properly.
Edit - Info on Lexus oil filter http://www.mkiv.com/techarticles/parts/toyota_filter/index.html
  • 2 weeks later...
wicked cheers
