Guest Bijal Posted February 3, 2007 Share Posted February 3, 2007 I am after a twin turbo engine (complete in good condition) with the turbos, prefer it off a 6spd. please email me at [email protected] or pm me. can arrange pick up. cheers bijal Link to comment Share on other sites More sharing options...
dk_supra Posted February 5, 2007 Share Posted February 5, 2007 I have one that is being prepared at the moment specs are 2JZGTE (Block has 30,000klm) New pistons, new rings, new rod bearings New oil pump New gakset kit New ARP studs UK spec cams UK twin turbos New Stiffer valve springs perfect for cams etc. UK 550cc injectors Complete UK harness, with ignitor and ECU (your choice manual or auto) Of course new timing belt etc. etc. In case you want, new 264s cams and new 850cc injectors. Complete with Alternator, A/C pump, P/S pump and starter. won't be cheap but it's just being perfected and will be sitting as stock. Link to comment Share on other sites More sharing options...
dini_the_owl Posted February 6, 2007 Share Posted February 6, 2007 hi mate, did you get the p.m Link to comment Share on other sites More sharing options...
Guest Bijal Posted February 6, 2007 Share Posted February 6, 2007 I have one that is being prepared at the moment specs are 2JZGTE (Block has 30,000klm) New pistons, new rings, new rod bearings New oil pump New gakset kit New ARP studs UK spec cams UK twin turbos New Stiffer valve springs perfect for cams etc. UK 550cc injectors Complete UK harness, with ignitor and ECU (your choice manual or auto) Of course new timing belt etc. etc. In case you want, new 264s cams and new 850cc injectors. Complete with Alternator, A/C pump, P/S pump and starter. won't be cheap but it's just being perfected and will be sitting as stock. just pm'ed, thanks. hi mate, did you get the p.m got your pm, thanks for that. will ring him tomorrow. cheers bijal Link to comment Share on other sites More sharing options...
veilsideTT Posted February 6, 2007 Share Posted February 6, 2007 Bijal have you tried jezzybabes? If he hasnt got one (which i doubt) he will find you one dude. Scotty Link to comment Share on other sites More sharing options...
