Chris and Alana Posted February 3, 2007 Share Posted February 3, 2007 hi guys. I recently fitted a nur spec r and first decat and Im overboosting to 18 psi. I have a 2" rr but can I put it in the first joint from the blitz back box? thats the joint on the bit of pipe from the back box. or does it have to be further back. thanks. Also is it ok to have a rr fitted when the second cat is still in and does a rr change the sound of the exhaust. I know theres alot of questions but I need this sorted. Thanks for the help guys Link to comment Share on other sites More sharing options...
Chris and Alana Posted February 3, 2007 Author Share Posted February 3, 2007 anyone Im off work today and have all the bits to put the rr in but im just not sure about the above. Link to comment Share on other sites More sharing options...
squiffy Posted February 3, 2007 Share Posted February 3, 2007 i had my rr inbetween the decats mate Link to comment Share on other sites More sharing options...
Chris and Alana Posted February 3, 2007 Author Share Posted February 3, 2007 I know the most common place to put it is just after the second cat or decat but does it matter where it goes? a restriction is a restriction isnt it . . . . . and I thought the further away from the engine the better so I thought I would put it in the next joint back (between the back box and the mid section of the blitz exhaust) plus I didnt want it just after the second cat as it may cause more heat build up within the cat itself..... oh im confused. all I want to do is bring my boost down to about 1 - 1.1 bar without stupid EGT's Link to comment Share on other sites More sharing options...
merckx Posted February 3, 2007 Share Posted February 3, 2007 I've put mine after the second decat . But any location will do. Link to comment Share on other sites More sharing options...
Chris and Alana Posted February 3, 2007 Author Share Posted February 3, 2007 right iv just fitted my 2" rr but when I got under the car evey exhaust joint I payed someone to do was leaking [ANGRY][/ANGRY] so I had to undo them all a paste them up and put them all back together, wot a pain in the arse but there all gas tight now anyway I still have my second cat in and I had runaway boost, it kept rising to 18 psi then fuel cut occured but now I have my rr in aswel it has brought the boost down to a stready 13psi (0.9 bar) in every gear which is good, but its a little low now:( I want about 14.5 psi (1bar) I think I need to file some of the rr away to make a bigger hole but does anyone know by how much? Link to comment Share on other sites More sharing options...
Flip Posted February 3, 2007 Share Posted February 3, 2007 Trial and error - take the ring out, file a bit off, put it back in, see what peak boost is. Rinse and repeat as necessary. Alternative is to get a nice boost controller in there to sort it out for you, that is the best way, it'll will give you a much more reliable and scientific approach! Link to comment Share on other sites More sharing options...
Ric Posted February 3, 2007 Share Posted February 3, 2007 My RR is 2.1 2.2 " Internal diameter and is giving 1.0bar with the 2nd cat in. Link to comment Share on other sites More sharing options...
Lewis Posted February 3, 2007 Share Posted February 3, 2007 agreed, I think a boost controller is the order of the day here, you will be hitting higher boost levels due to the cold weather, once summer comes along you may find your boost levels a fair bit lower. Go with a BC and you can up it when required. Link to comment Share on other sites More sharing options...
Flip Posted February 3, 2007 Share Posted February 3, 2007 Trouble with going to 2.1" diameter is that might put you over! Each engine boosts differently, there are people on here with no RR in there not getting above 1 bar! Definately boost controller, you get a few on the for sale area for between £100-£150... Or spend £400 on the i-color coz its really cool! That's got more features/options than an S-class Merc! Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted February 3, 2007 Share Posted February 3, 2007 So what's so wrong with 18Psi then? OK, it's probably a little high if you still have the 2nd cat in place, but it isn't anything overly bad though. I used to run my twins with no cats at 18 Psi all the time, they lasted fine. Link to comment Share on other sites More sharing options...
Chris and Alana Posted February 3, 2007 Author Share Posted February 3, 2007 So what's so wrong with 18Psi then? OK, it's probably a little high if you still have the 2nd cat in place, but it isn't anything overly bad though. I used to run my twins with no cats at 18 Psi all the time, they lasted fine. because it wasnt steady it was creeping up to that boost and would go further if fuel cut didnt happen. the rr is keeping a nice steady boost level. So can I just buy a EBC and up the boost? will the EGT's be ok with the second cat in and a rr and then turning the boost up to say 1.1 bar? Link to comment Share on other sites More sharing options...
