MOT worries Please HELP
G-NEMIE
OK Now Im Worried :(
Just been reading http://www.mkivsupra.net/vbb/showthread.php?t=98224 regarding ALL MK IV SUPRA's need at least 1 cat in to pass the MOT now.
Any model, any age from chassis number 0000001 onwards. It seems that at some point recently, vosa/dvla have updated their computers and you now need a CO2 reading below 0.2 to pass.
Toyota Supra 3ltr TT J-Spec GZ
My Car I BPU with "Chris Wilson" Double Decat
My MOT is next thursday (8th FEB)
1. Does anyone have any idea if you can change 1 cat back or do you have to do both ?
2. Does any one have a 2nd Cat (or the two depending on the answer of number question number 1).
on the last MOT (pre decats) the readings were Co2 0.115 (Fast Idle) & Co2 0.071 (Natural Idle) so now with the cats out Hmm?
Of Couse I Just need to Borrow, and will collect and return ASAP.
midlands area, etc as i live in shropshire not far from Chris Wilson
Chris W if your reading, do you know if you have the 2nd cat (cornelius seems to think you would keep hold of it)?
what would you suggest ?
cheers
jamie
2 days to go to the MOT
All i can say is "Chris Wilson , your are a star".
chris has found the Cat that was taken off and fingers crossed im at least in with a chance.
just got to fit it now !
any other tricks / suggestions to pass emissions test (long drive before hand etc)
cheers
jamie
:ecstatic: :ecstatic: :ecstatic: :ecstatic: :ecstatic: :ecstatic:
PASSED
Need to get the Decat back on NOW`!
Emissions test is based different category depending on age of car, and not if its j-spec or uk spec, there all the same .
so based on being 1993 it was tested as if it should have a cat on.
RESULTS :
FAST IDLE maximum C0 0.20% vol Actual 0.05 % vol
NATURAL IDLE maximum C0 0.30% vol Actual 0.19% vol
oh and needed new number plates as the Spacing was wrong.
ta
jamie
RESULTS :
ta
jamie
Mine the other day was 0.02 and 0.00 ;) i was well impressed
