Oil leak in head gasket area..
_Rob_
Im in the process of changing my timing belt. I noticed a light film of oil behind timing belt cover no. 2 once id taken it off. this film was only below the head / block join. Upon wiping this oily film off the block, i noticed the oil near the corners of the head was gold, almost fresh, when compared to the rest, which was a mucky grimey kind of oil. I looked to the sides of the block and had a feel, again in the corners near to the front, and i had gold oil on my fingers again. Now this is only a little bit of oil, nothing massive. However, im worried as the only place it could be coming out of is the HG, isnt it?
When the car runs, there is no problems, no white smoke, just a little condensation on cold mornings. I had a tad of blue on start up, however after i removed that CATs, this dissapeared.
My main question is...can i put it back together and hope for the best? :)
Could the head bolts have become loose over time? maybe try torquing them up a bit?
Any advice appriciated!
cam cover gaskets? thought it was cam shaft seals? :)
ive got the cam covers off at the mo cos the gaskets were leaking slightly at the back. But this leak is at the front, and way lower down that the cam covers. And there doesnt seem to be an oil trail from the cam covers.
Ahh ok my fault....then yes they may need to come out :(
