Air Con Unit
heckler
whats wrong with the unit? as may be able to help as have parts of one
two of the LED's dont work, when the buttons are pressed, but the led's themselves work when direct power is applied. AND.. the fan speed only work one way, i can get it to max speed using the knob, but it wont turn down the speed.
:blink:
i bet its the 2 at the bottom row?, i have had this a couple of times, its the actual pot that you turn for the fan speed that causes the problem, you have to replace that, unfortuantly i have already used that part for one of mine when it did the same thing, not sure what kind of switch/pot it is and dont know if you can buy a replacement.? Baffled me when i first came across this problem!
ahha.... i'll look into this then.... cheers fella
