alloy wheels
jonshaw_uk
I have been looking for a set of rims for my J spec supra and cant seem to fnd many. What other makes and model cars would the wheels fit on to the supra?
I found cars with the same pcd and off set but different centre bore size. Does the centre bore size make much difference?
Jon
Almost every single alloy wheel available has a larger centre bore size.
When you buy a set of wheels the supplier will include a set of "Hub Centric Rings".
They sit inside the wheel bore so when you fit them on your car they will give you a nice snug fit .
They will be made from either aluminium or plastic.
centric rings
Have a look here. That's a list of wheels known to fit over the UK brakes which I know you haven't got, but they will certainly all fit on a J spec too. It's probably worth buying wheels that will clear the bigger brakes anyway - you may well upgrade to them in the future.
