850cc injectors too big for stock fuel rail?
MONKEYmark
hi
just trying to sort out a fuel system out for when i go to fit single kit. i had it in my head i was going to use stock fuel rail modified with a -6 feed each end, then get some BLITZ 850cc side feed high impedence injectors to drop in stock rail. i know terry and others have done it. have been advised that the stock fuel rail wont flow enough fuel.
think the injectors should be more than enough for the turbo
just looking for info on what to do. try my luck with stock rail or if to jump in and get a full kit - the 2 fuel pumps i have now.
whats all the single turbo people gone with.
just dont want to go with wrong set up.
thanks
Guest Terry S
Mark that was the first set up in the purple car. Will be fine mate. BTW, we will have the modded rails if that's any use to you.
Dusty @ MVP is trying to sell me the exact same setup mate. He assures a perfect fit and it says its been done loads of times.
What kinda price have you got on the 850 Blitz injectors? I might be able to get a good deal from the good old US of A. :cool:
Guest Terry S
Jason we can match the MVP cost.
Be careful, 850 is too big for the SAFC to cope with really without messing with the timing. The 650's aren't. On your size turbo 850 is overkill.
$125 + shipping each seen a stock rail for $50 + shipping to experiment on.
jason do you work on an airbase?
i found a good place for cheap GM sensors but they wont ship to uk unless its a US military address overseas
I can get stuff shiped to a US air base in this country :D
Dude:flame Dev
Dude:flame Dev
it was just one store that wont ship to uk. other stores only deal with bank wire transfers. some stores bend other backwards to help you.
its amazing how much prices differ from £69 + shipping us price. to £140 in the uk price. bit of a difference and plenty to be saved on 6 injectors. :eek:
i love the world wide interweb
Exactly. I do work for the US Gov, so I can get those shipped to that same type of address avoiding VAT + Duty. Lemme know.
-J
90 quid is about equal to the price I can get from Dusty.
Just curious what brand yours are? For 90 quid, I can get Blitz 850cc direct fit injectors.
is your name JASON not good with names.
are you running 550cc uk injectors on stock rail with resistor pack?
and are you going to go with stock rail modified with a feed each end with 2 pumps and 850cc injectors.
got a diagram off net which shows you how they done a fuel set up.
think the stock rail modified is just a hole drilled into each end with new aeroquip -6 fittings. seen a stock rail forsale for $50 which would be good to experiment on. could get engineers at work to do it.
how much are stock rails to buy,
Guest Terry S
Jason, they would be blitz 850cc. IMHO they are too big for the SAFC without some form of timing control.
