Fitting FMIC
Paul Laing
This weekend i'm going to be fitting my HKS FMIC, has anyone got any tips on how to take off the front bumper? Some people say 3 hours (bodyshop) and some say a hour or so. How long has it took you guys in the past. How many bolts is there and where abouts are they all? Any good guides?
Also do you have to do anything else, i'm wanting to keep my active spoiler down permanently instead of taking it off. Do i have to disconnect anything to stop the light from flashing or anything else i might miss?
Cheers,
Paul
If i remember correctly - it took me about an hour to remove the bumper and 4.5 hrs in total start to finish.
Take a look here for pics.
there are 4 bolts which hold the bumper on, 2 can be seen when you remove the lights. - the others can be reached from the front - but its easier to remove the wheel arch liners
The black strip (with 5 plastic screws) needs to be removed, as do the black strips (again with black plastic screws),
remove the engine undertray, and the one that attaches to the bumper (I think 5 bolts)
There are alot of screws - I have bags and bags of left over screws!
You'll need a container to catch the PAS fluid when you change the PAS cooler - as a result you'll need some more PAS fluid. You'll also need to bleed the PAS system
from the pics you'll see I also removed the active spoiler as the FMIC pipes come through where the auto spoiler motor attaches to the car. (5th pic down on right hand side of page)
ALSO - If you re-attach the front section of the engine cover (the part which bolts t0 the bumper - you'll need to cut a section out (as per HKS installation instruction) - this was a pain in the ass to do - When I changed my bumper - I binned this part.
Hope this is of some help - Any questions gimme a PM
But I'm sure there are more "knowledgable" people on than me.
:thumbs:
Cheers Mcanny, Heckler :thumbs:
Heckler - How do you bleed the PS system? Mine makes some strange noises at start up and i have recently changed my ps tank to a chromed one so really it should need bleeding now. So will do this when i change the intercooler.
Any help on how to do this would be great :)
Start the car with the cap off the power steering reservoir and turn the steering slowly from lock to lock a few times until it stops making a horrible noise. Then top up the fluid level to the correct level. You might have to do it a few times to get all the air out.
the way I did was...
1) jack the front end up,
2) turn the whell lock to lock several times...
3) Check the PAS fluid level - top up if req'd
4) Start engine turn the whell lock to lock several times...
5) check the PAS fluid level - top up if req'd
6) Engine Off - turn the whell lock to lock several times...
7) check the PAS fluid level - top up if req'd
repeat 2 - 6 until theres no bubbles in the PAS Tank, job done.
this method no fluid gets spilt.
When I fitted my FMIC - I ended up putting over 1/2 ltr PAS fluid back in.
exactly the same for me aswell :)
yeah short the plug that normally plugs in the spoiler motor and the same on the switch behind the dash
theres instructions on mkiv.com i think cant remember where i got them from now
and then just bolt the spoiler up if you are wanting to leave it permantly down :) all good
just unplug the active spoiler ecu behind the stereo head unit:)
Once an FMIC is fitted, the only way to have the spoiler down is having it fixed down with brackets. A bit of a PITA, shame nobody has made up a smaller motor (as this is what gets in the way) to allow keeping it. It certainly plays its part past 140.
