supra steveo Posted January 30, 2007 Share Posted January 30, 2007 my power steering pulley has started to squeek think it might be with the amount of rain and the holes in my TRD bonnet is it just a case of belt off, socket on, pulley off and grease the bearings then reassemble ? Link to comment Share on other sites More sharing options...
Rob Posted January 31, 2007 Share Posted January 31, 2007 How you know it that pulley exactly? heh? heh? International Talk Like a Mexican day Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 31, 2007 Share Posted January 31, 2007 Its more likely to be the belt getting worn, mine was just the same, thought it was the pump,got temporary relief by spraying with WD-40 but after belt change no more noise. Link to comment Share on other sites More sharing options...
Daston Posted January 31, 2007 Share Posted January 31, 2007 you sure its not the crank pulley? Link to comment Share on other sites More sharing options...
NUTKIN Posted January 31, 2007 Share Posted January 31, 2007 For god sake do the tip-ex trick put a line of tip-ex across the pulley from inner to outer then if its slipping the lines wont meet up when u check. Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted January 31, 2007 Share Posted January 31, 2007 For god sake do the tip-ex trick put a line of tip-ex across the pulley from inner to outer then if its slipping the lines wont meet up when u check. WHAT ...... Link to comment Share on other sites More sharing options...
supra steveo Posted January 31, 2007 Author Share Posted January 31, 2007 How you know it that pulley exactly? heh? heh? because i had my head right next to it and i could hear it squeeking Its more likely to be the belt getting worn, mine was just the same, thought it was the pump,got temporary relief by spraying with WD-40 but after belt change no more noise. i changed the belt not to long ago For god sake do the tip-ex trick put a line of tip-ex across the pulley from inner to outer then if its slipping the lines wont meet up when u check. will try that and tighten the nut if needed Link to comment Share on other sites More sharing options...
Rob Posted February 1, 2007 Share Posted February 1, 2007 Tightening the nut won't help. Search crank pulley, or click that live link there. You may well be right, but there are far more reasons for it to be the crank pulley than the PS pump pulley. Link to comment Share on other sites More sharing options...
supRo Posted February 1, 2007 Share Posted February 1, 2007 It's probably the power steering pump bearing which is common. You can get the bearing and seal kit (both separate part numbers) for from Toyota. Worth doing if your PS pump is in good condition - needs to be taken apart and checked for play e.t.c Link to comment Share on other sites More sharing options...
supra steveo Posted February 1, 2007 Author Share Posted February 1, 2007 might pull it apart this weekend for a play i will probibly lose all the bits but fuck it Link to comment Share on other sites More sharing options...
