JamieP Posted January 30, 2007 Share Posted January 30, 2007 Jonty has just brought the GT4088R, im gonna see how he gets on with that and may upgrade:) Link to comment Share on other sites More sharing options...
kosmic Posted January 30, 2007 Share Posted January 30, 2007 Glad you liked it mate:) Im well happy with it, anyone else wants a demo give me a shout. I told you id convert you:D Still waiting for my demo Jamie Can i bring the misses along? Link to comment Share on other sites More sharing options...
RobSheffield Posted January 30, 2007 Share Posted January 30, 2007 Jonty has just brought the GT4088R, im gonna see how he gets on with that and may upgrade:) Sounds good Link to comment Share on other sites More sharing options...
VELOCITY Posted January 30, 2007 Share Posted January 30, 2007 I am booking mine in at Turbo fit and they recommended this turbo to, so may go with the same one, Would love a demo sometime if its not too much trouble jamie. Link to comment Share on other sites More sharing options...
ajazyasin Posted January 30, 2007 Share Posted January 30, 2007 the gt4088 is $899 and the gt4088r is $1899. What is the effective difference? Is it that is spools slightly quicker? $1000 for a few 100 rpms quicker spool doesnt add up for me. Looking at the 2 fact sheets for the turbos, they seem to generate the same power. Im probably missing the point but once again, forgive my ignorance on this. Link to comment Share on other sites More sharing options...
Guest dee_rz Posted January 30, 2007 Share Posted January 30, 2007 Anti surge hype??? no it does as it would surgest, it both aids spool and stops turbo surge look up turbo surge on google or something similar. the gt4088 is bigger than the 4067 and also it does have a better inturnal organs as such lighter blades and i think a different amount of blade and does allow it to produce more power and have better spool than the 4067. I have the gt4088R and have the garratt version very good turbo not much difference from the gt4088 to the R version only the R has anti surge and dbb alot of money more and no more power just spool circa 300 rpm sooner. Does that make it worth the extra?? you deside. To answer the question on the ar sizes yes the bigger you go the higher the boost threshold will be but more power can be made, big ar's and trim on exhaust side will = high top end or top rev power and visa versa. Hope you get my points if not feel free to pm me for anymore info Link to comment Share on other sites More sharing options...
Thorin Posted January 30, 2007 Share Posted January 30, 2007 I thought turbo surge was only an issue if you'd got a badly matched turbo housing size for the engine size. I don't hear lots of non-anti surge single owners complaining of surging problems. Link to comment Share on other sites More sharing options...
Jake Posted January 30, 2007 Share Posted January 30, 2007 Anti surge hype??? no it does as it would surgest, it both aids spool and stops turbo surge look up turbo surge on google or something similar. That's not what the guy who owns Powerhouse Racing says: http://www.mkivsupra.net/vbb/showthread.php?p=943331&highlight=anti%2A#post943331 Link to comment Share on other sites More sharing options...
Gamer Posted January 30, 2007 Share Posted January 30, 2007 On the GT4088R the 40 means it is a GT40 turbine wheel which is 77mm and 73 trim all of the GT40 turbine wheels have these specs, now the 88 means that the EXDUCER is 88mm 54 trim and Inducer is 64.7mm and the compressor housing is .72 A/R On the Precision GT4067R we got a kicker but still the same on the GT40 portion which pertains to the turbine wheel again 77mm and 73 trim all of the GT40 turbine wheels have these specs. Here is the kicker the 67 means this turbo has a 67mm Inducer and 84.07mm Exducer So the 4067 is smaller on the exducer and larger on the inducer. a few things worth noting -the larger 67mm wheel does not necessarily move more air than the 64mm 4088 wheel -gt40 turbine wheels are cut down gt42 wheels -turbine a/r size has a HUGE amount to do with the turbos performance (often overlooked) -divided inlet turbos (most of these) have a downside. The 4088 wheel has 14 "scoops" and the 67wheel has 12 "scoops" the 4088 scoops more air, but it will warm it up faster because it grabs more. divided inlet turbos have half the volume for the same size pulse. they make the flow non-steady state and as a result, the turbine sees pulses. This is definitely not ideal IMO. back pressure problems are pretty much bound to happen with this setup. Spool up is better at the expense of top end flow. ported shroud compressor housings do move the surge line, at the expense of pulling more vacuum on the compressor wheel. The ported shroud increases the available air at choke flow. it essentially makes the inducer "virtually" bigger Link to comment Share on other sites More sharing options...
Alex Posted January 30, 2007 Share Posted January 30, 2007 Anti surge is for turbo's that arn't a good match to your engine. Link to comment Share on other sites More sharing options...
tbourner Posted January 30, 2007 Share Posted January 30, 2007 I need a ride in a single car some day - just hope it doesn't ruin my dream of one day having a nice single Aristo! Link to comment Share on other sites More sharing options...
Ian C Posted January 30, 2007 Share Posted January 30, 2007 Anti surge is for turbo's that arn't a good match to your engine. That's my understanding of it as well. One wonders if this turbo would actually surge if it didn't have said housing. Possibly not in which case it's a "shiny thing" that does nothing but costs money. Hmmm. Still, sounds like it delivers the goods. What gear are you in to hit 0.9bar at 3100rpm? I bet it's not 1st -Ian Link to comment Share on other sites More sharing options...
ajazyasin Posted January 30, 2007 Share Posted January 30, 2007 So maybe I should run my 4067 for a while and see how it performs. Link to comment Share on other sites More sharing options...
Marco Posted January 30, 2007 Share Posted January 30, 2007 Can you give me a demo on saturday Jamie? Never been in a single turbo supra :thumbs: Link to comment Share on other sites More sharing options...
Jonty Posted January 30, 2007 Author Share Posted January 30, 2007 Great to see all the info and comments - choices choices! The GT4088R I have ordered has both oil lube and water cooling. Oil acts as lubricant and water cools. Some people concerned about overheating water system. However according to Precision the water flows very quickly through the turbo housing and it not super heated etc. Will need to plumb in carefully to get optimal flow etc so it all works. Expecting near similar to Jamie performance as mine is built egine without manifold etc. Exhaust choice is my current challenge in getting the right one???? If my install delivers 75% of Jamie's results I'll be very happy. Be interesting to see how it all works together. Will keep you updated Br Jonty - I was condtioned to big turbo mentality - however for Superb Street use this set up is tops and delivers in spades. We will have 2 test ride cars available shortly. Link to comment Share on other sites More sharing options...
johnnyknox Posted January 30, 2007 Share Posted January 30, 2007 Ok Technichal guys,I'am thinking down the single route, this turbo what do I need to get a proper set up and what are we talking realistecly cost wise, my sup is currently BPU,What is the ball park figure. Mines coming in at about the 6k mark at present Link to comment Share on other sites More sharing options...
johnnyknox Posted January 30, 2007 Share Posted January 30, 2007 Anyone got any comments on the PowerRacing Stage 2? Link to comment Share on other sites More sharing options...
JamieP Posted January 30, 2007 Share Posted January 30, 2007 What gear are you in to hit 0.9bar at 3100rpm? I bet it's not 1st -Ian Lol, the best gear for making the turbo spool early, 6th;) Ill get some datalogs from Dan if i can. Ive got a boost leak at the min,1.4 dropping to 1.1 which has effected the spool slightly, im gonna investegate that on saturday. Link to comment Share on other sites More sharing options...
JamieP Posted January 30, 2007 Share Posted January 30, 2007 Can you give me a demo on saturday Jamie? Never been in a single turbo supra :thumbs: Hi Marco, Greg is fitting my Nos and im stripping the interior to fit my roll cage on saturday so if your still there when thats done then yea no probs mate:) Link to comment Share on other sites More sharing options...
Jake Posted January 30, 2007 Share Posted January 30, 2007 Anyone got any comments on the PowerRacing Stage 2?Never heard of it Did you mean PowerHouse Racing? Link to comment Share on other sites More sharing options...
Homer Posted January 30, 2007 Share Posted January 30, 2007 The GT4088R I have ordered has both oil lube and water cooling. Oil acts as lubricant and water cools. Some people concerned about overheating water system. However according to Precision the water flows very quickly through the turbo housing and it not super heated etc. Will need to plumb in carefully to get optimal flow etc so it all works. It doesn't overheat provided its plumbed in correctly James Turner had some issues with his but that was due to the pipework being wrong. Link to comment Share on other sites More sharing options...
johnnyknox Posted January 30, 2007 Share Posted January 30, 2007 Never heard of it Did you mean PowerHouse Racing? Yes Jake...I missed out the House bit, doh! (I won't bother editing my post, I'll let people see I'm a fool) Link to comment Share on other sites More sharing options...
Wez Posted January 30, 2007 Share Posted January 30, 2007 Anti surge is for turbo's that arn't a good match to your engine. Correct, surge is where the turbo is generating more flow than your engine can ingest at the given time. Link to comment Share on other sites More sharing options...
JamieP Posted January 30, 2007 Share Posted January 30, 2007 What happens if you get turbo surge? and what would the down side to a antisurge housing be if any? Link to comment Share on other sites More sharing options...
Wez Posted January 30, 2007 Share Posted January 30, 2007 divided inlet turbos have half the volume for the same size pulse. they make the flow non-steady state and as a result, the turbine sees pulses. This is definitely not ideal IMO. back pressure problems are pretty much bound to happen with this setup. Spool up is better at the expense of top end flow. Divded housing are supposed to increase spool utilising the different pulses from the cylinders. For this to work most effeciently they should be matched to a divided manifold which optimises the exhaust pulses. My motor uses a non DBB divided housing and my spool is pretty good. Link to comment Share on other sites More sharing options...
