Local jap breaker
crashoverride
hi guys,
just thought i would let you know i have found a local specialist breaker. they are called easy jap parts in birmingham.
i spoke to them today enquiring about a de-cat pipe. i was told they will fabricate a one off 2nd de-cat pipe for the soop for £150 they will also push through the 1st cat clean out and refit for just £30.
when i mentioned the forum they said if anyone from the forum contacts them and gives my name along with the forum they will give a small discount on parts.
if anyones intrested drop me a pm for the details;.
cheers
class one sorry but whats with the abrupt NO! how about no and a possiable explanation for it, surly thats the polite way to do it?
Sorry, just my way sometimes. Don't read anything into it that isn't there. £150 for a 2nd "custom" decat isn't a great price when if you shop around you'll discover that you can get both made up for about £170 IIRC.
As for "custom", well they're all that seeing as they're no an oem item.
I'd probably leave the first cat alone mate. When i double decated my NA you could here it from space! and I’m not exaggerating! (read this thread post #768 onwards http://www.mkivsupra.net/vbb/showthread.php?t=77467&page=52 )..
If you bore it out and find its too loud then you'll be looking for another cat... I bought a 2nd hand decat pipe off here for £80 about a month ago. 1st De-cat for an NA is expensive though because it branches into two pipes. Think Chris Wilson sells them for £180 each but they are a welding work of art ;)
