Bob Posted January 29, 2007 Share Posted January 29, 2007 I've just tried starting the car and things have gone very very wrong. The lights come on as normal, everything starts up fine. Then I turn the key all the way round to start the engine and several things happen . . . There is a loud click, and I lose all power So, I release the key and take it out and The ignition barrel and interior light start flashing, accompanied by loud clicks from the direction of the ignition barrel, followed then by The headlights flashing a few times, then the indicators flashing twice and the alarm beeping (2 flashed and 2 beeps = alarm disarmed), the ignition barrel and dials flashing another couple of times, then the car goes dead. All with no key in the ignition. I'm scared. I've also taken the battery out to charge it, just in case it has something to do with that. Shouldn't be though, as it's one of the big Halfords ones with the 3 year guarantee, only 12 months old. Link to comment Share on other sites More sharing options...
D8MOA Posted January 29, 2007 Share Posted January 29, 2007 sounds like you have a alarm problem Link to comment Share on other sites More sharing options...
letmeshowyou Posted January 29, 2007 Share Posted January 29, 2007 what alarm is it? I wouldnt be surprised if this was all battery related. Make sure when you connect it back up everything is tigh as it should be. Link to comment Share on other sites More sharing options...
Bob Posted January 29, 2007 Author Share Posted January 29, 2007 It's a Toad Ai606, though admittedly I don't think the interior sensors have ever worked Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 29, 2007 Share Posted January 29, 2007 Either the battery is very flat, dead or both, or the battery terminals or earth lead are insecure, corroded or otherwise buggered. Link to comment Share on other sites More sharing options...
Bob Posted January 29, 2007 Author Share Posted January 29, 2007 Thanks, just checked the Earth connection and it was slightly loose - problem solved, panic over I've just been fiddling with the climate control unit, so thought I may have fubar'd something there! Link to comment Share on other sites More sharing options...
_Rob_ Posted January 29, 2007 Share Posted January 29, 2007 Its funny how a poor earth connection gives loads of flashing lights and strange noises! Link to comment Share on other sites More sharing options...
Bob Posted January 29, 2007 Author Share Posted January 29, 2007 Yeah, never had this happen before. Very bizarre! Link to comment Share on other sites More sharing options...
Chewie Posted January 29, 2007 Share Posted January 29, 2007 What happens is the electric current tries to find the next best path of least resistance. I had something similar happen to my old 205 GTi whenever you indicated the headlights flashed. Took alot of staring at the circuit diagram to work that one out. Link to comment Share on other sites More sharing options...
Bob Posted January 29, 2007 Author Share Posted January 29, 2007 Well I never. Cheers, I've learned something new today! Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 29, 2007 Share Posted January 29, 2007 Yes, all down to incorrect earth return paths. Link to comment Share on other sites More sharing options...
Chewie Posted January 29, 2007 Share Posted January 29, 2007 However many people did claim that my 205 was haunted and I should take it to my local exorcist. Swearing and gratuitous profanities were often heard from the drivers seat during the dawn and sunset rush hour grid lock. Link to comment Share on other sites More sharing options...
Rob Posted January 30, 2007 Share Posted January 30, 2007 Either the battery is very flat, dead or both, or the battery terminals or earth lead are insecure, corroded or otherwise buggered. Are you saying it could be a battery problem? Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 30, 2007 Share Posted January 30, 2007 Are you saying it could be a battery problem? I thought that was fairly evidently a "yes".... ? Link to comment Share on other sites More sharing options...
Rob Posted January 31, 2007 Share Posted January 31, 2007 So it could be the battery then? Link to comment Share on other sites More sharing options...
Bob Posted January 31, 2007 Author Share Posted January 31, 2007 It was either the earth connection or the holy water that did the trick. Link to comment Share on other sites More sharing options...
paul ashton Posted January 31, 2007 Share Posted January 31, 2007 It was either the earth connection or the holy water that did the trick. Are you sure that it wasn't the mucky water that did the trick? LOL. Link to comment Share on other sites More sharing options...
