SimonB Posted June 22, 2004 Share Posted June 22, 2004 I'm going to make a custom front undertray, as the stock one won't fit any more due to my bumper and FMIC. I was planning on using sheet aluminium as it's nice and light, won't rust and should be man enough for the job. Anyone know where I can get a big enough sheet of aluminium from? B&Q do thin stuff, but not in a big enough sheet I think. It obviously has to be the same width as the car. Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted June 22, 2004 Share Posted June 22, 2004 doesnt have to be the same size as car does it a couple of Rivets to hold together will do, this will also help if damage occurs meaning you could rplace just half of it instead of all of it. Obviously if the peice is a foot wide Link to comment Share on other sites More sharing options...
Paul Posted June 22, 2004 Share Posted June 22, 2004 Pooh, I used to work for a big Ali supplier and could have got you some for sod all, bastards 'Corus' shut the site though. Thinner ali will be alright if you form ridges in it to give it some strength, otherwise it'll rattle around like a good 'un. What about the yellow pages, some of your more 'upmarket' scrap dealers will be able to supply sheets and cut it for you. You could try a trade metal suppliers but they usually have a miniumum order value, ask if they have offcuts though and say it's cash and they may sort you something. Paul Link to comment Share on other sites More sharing options...
Nick_TC Posted June 22, 2004 Share Posted June 22, 2004 Look in the yellow pages for a local metal supplier, sheets tend to come in 2mx1m or 8'x4' Link to comment Share on other sites More sharing options...
SimonB Posted June 22, 2004 Author Share Posted June 22, 2004 Cheers guys, I'll have a look for a local metal dealer. What thickness do you reckon I should go for? It's going to be bolted to the mid undertray at the back and the bumper lip at the front and it needs to be thin enough so I can cut it with some shears without too much effort! Do you think 0.5mm will be thick enough, or 1mm? Link to comment Share on other sites More sharing options...
Nick_TC Posted June 22, 2004 Share Posted June 22, 2004 .5mm will be like kit kat paper, I'd go for 18swg (1.2mm) or 1.6mm (16swg) Link to comment Share on other sites More sharing options...
Syed Shah Posted June 22, 2004 Share Posted June 22, 2004 Mohd at http://www.mohdparts.com already does these. Writeup on his site. Fast delivery, easy to fit, good price. Link to comment Share on other sites More sharing options...
eldudereno Posted June 23, 2004 Share Posted June 23, 2004 You'll probably find that Sheet Metal Stockists will be thin on the ground........look on yellow pages for Metal Fabricators as there is a lot more around and I'm sure they'll sell you a bit... Link to comment Share on other sites More sharing options...
Alex Posted June 23, 2004 Share Posted June 23, 2004 Originally posted by Syed Shah Mohd at http://www.mohdparts.com already does these. Writeup on his site. Fast delivery, easy to fit, good price. can't see a full undertray on there which stretches to the oil sump. Can you post a link to it directly? Or were you talking about the FMIC bottom panel - which is something else I believe. Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 23, 2004 Share Posted June 23, 2004 Often find people selling sheet ali cheap HERE Or look under "None Ferrous Metal Suppliers" in Yellow Pages. You need something soft to work it easily, I only keep hard aircraft grade stuff that's structural and expensive, so I haven't anything really suitable. To do a neat and professional job will be tricky with home workshop stuff. Link to comment Share on other sites More sharing options...
Guest Terry S Posted June 23, 2004 Share Posted June 23, 2004 I made one for the Purple car which worked great. Leon has just done one on the Orange car. Maybe give him a bell as the guy how made his did a lovely job. Mine was a labour of love..... Link to comment Share on other sites More sharing options...
Nick_TC Posted June 23, 2004 Share Posted June 23, 2004 I've got it in stock, but will be a bitch to post Link to comment Share on other sites More sharing options...
SimonB Posted June 23, 2004 Author Share Posted June 23, 2004 Originally posted by Syed Shah Mohd at http://www.mohdparts.com already does these. Writeup on his site. Fast delivery, easy to fit, good price. Yes he does, but only for the stock bumper and HKS S type FMIC. I have a Blitz and a Whifbitz front bumper. It doesn't look too hard a job actually, because the bottom of the bumper has a lip which the plate will sit on, and this is at very nearly the same height as the rear attachment point, which will be the front of the engine undertray where the stock front undertray attaches. So it won't need much if any bending. It's only going to be replacing the front undertray, not the one under the engine itself. I'm making a cardboard template at the moment - I'll post up some pics when I get something together. Link to comment Share on other sites More sharing options...
Syed Shah Posted June 23, 2004 Share Posted June 23, 2004 It fits any FMIC, not just the S-type. Not sure about the bumper though, fancy posting a pic from underneath yours? Alex, Mohd does not do a engine one, just the front one AFAIK. Link to comment Share on other sites More sharing options...
SimonB Posted June 23, 2004 Author Share Posted June 23, 2004 It says on his website: Overview: if you own a Type-S HKS FMIC then this bottom FMIC panel will play an important role in the cooling system by helping incoming airflow to pass directly from the Bumper, FMIC to the Radiator without leaking through the lower big gap between the Bumper & FMIC due to the removal of the factory plastic under cover, this improves the cooling system efficiency! I'll see what I can do re: photo of the underside. It's a bit wet and windy atm! Link to comment Share on other sites More sharing options...
Syed Shah Posted June 23, 2004 Share Posted June 23, 2004 But it fits with other FMICs as well, that is just what he had. Yep bad weather to take pics, serves you right for not sticking your baby in the garage Link to comment Share on other sites More sharing options...
colsoop Posted June 23, 2004 Share Posted June 23, 2004 I dont know if this is useful to you but there is some aluminium sheets on e bay. http://search.ebay.co.uk/sheet-aluminium_W0QQmaxrecordsreturnedZ300QQsalocatedincountryZ3QQsocurrencydisplayZ2QQsokeywordredirectZ1QQsorecordsperpageZ50QQsosortpropertyZ1 Link to comment Share on other sites More sharing options...
SimonB Posted June 23, 2004 Author Share Posted June 23, 2004 Originally posted by Syed Shah Yep bad weather to take pics, serves you right for not sticking your baby in the garage It won't fit, my garage is too full of Supra bits! Seriously, I think it would just fit, but I'd have to teleport out of the car... Link to comment Share on other sites More sharing options...
