Joe. Posted January 27, 2007 Share Posted January 27, 2007 Any one here know of how light a twin turbo man can be gotten down to ? as in stripping all unwanted peices from the car, use light pannels and glass ? Would i be mad in saying I want to get mine under 1100kgs ? Link to comment Share on other sites More sharing options...
Homer Posted January 27, 2007 Share Posted January 27, 2007 Any one here know of how light a twin turbo man can be gotten down to ? as in stripping all unwanted peices from the car, use light pannels and glass ? Would i be mad in saying I want to get mine under 1100kgs ? Depends on what your aim is really. For a drag motor you chop everything out and tube it with CF panels. Should be less than 1000kg, most of which will be your engine and tub frame. Link to comment Share on other sites More sharing options...
Joe. Posted January 27, 2007 Author Share Posted January 27, 2007 its not being built for drag but drifting, have a full set of windows on the way for the car alongwith a strict diet plan for the car, the car cant be space framed or cant tub it out at the front or rear Link to comment Share on other sites More sharing options...
Homer Posted January 27, 2007 Share Posted January 27, 2007 1100kg is a no go then. Not even close. Link to comment Share on other sites More sharing options...
colsoop Posted January 27, 2007 Share Posted January 27, 2007 Have a look here: CLICK ME Go to the weight reduction tab for ideas of what you can strip and also check the lightest supra tab. 2921 pounds ! although it doesn't specify what was done to achieve that figure. There is plenty of weight to shift in the supra i think without mega money being spent you could get it down to 1200 KG Good luck Link to comment Share on other sites More sharing options...
Chewie Posted January 27, 2007 Share Posted January 27, 2007 It's such a heavy car to start off with. That's why 200SXs are top choice for drifting. Link to comment Share on other sites More sharing options...
colsoop Posted January 27, 2007 Share Posted January 27, 2007 It's such a heavy car to start off with. That's why 200SXs are top choice for drifting. how much does a 200sx weigh ? Link to comment Share on other sites More sharing options...
Joe. Posted January 27, 2007 Author Share Posted January 27, 2007 I think ill get it under the 1100kg mark no problem, We have got last years drift 180sx down to 1040kgs with all glass and metal doors,1/4's and boot door Have fiberglass doors, 1/4's and boot door comming along with lezan windows all round inc front screen, so close to 950kgs is the target. the car will be striped to bare shell and fitted with a custom cage and then the shell will be stripped of any unwanted metal it will have no air con,or heater box and stock fuel tank removed etc and a full comstom wiring loom to be used Link to comment Share on other sites More sharing options...
bondango Posted January 27, 2007 Share Posted January 27, 2007 If your throwing everyting at it, i guess it is possible. Carbon fibre where ever possible including Driveshaft, the new d1 soarer has a full CF dash, use lighter suspension components, even with the engine thres a few things - lightened Fly wheel, pulleys, ditch viscous, aircon, maybe altenator, ditch the TT setup and run a single GT3037 Pro-S(favoured by Kunny and T&E on the D1 2jz's). Dee Irelands supra was put on a strict diet but i dont know what the final weight was on it. Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 27, 2007 Share Posted January 27, 2007 Any one here know of how light a twin turbo man can be gotten down to ? as in stripping all unwanted peices from the car, use light pannels and glass ? Would i be mad in saying I want to get mine under 1100kgs ? I'd say getting under 1100 kgs would be very costly and it would be race only, in reality. Link to comment Share on other sites More sharing options...
hadyn Posted January 27, 2007 Share Posted January 27, 2007 how much does a 200sx weigh ? S14s are about 1200kg Link to comment Share on other sites More sharing options...
keron Posted January 27, 2007 Share Posted January 27, 2007 also i would change the doors to cf ones as the original doors weigh loads....also the boot lid too. Link to comment Share on other sites More sharing options...
Chewie Posted January 27, 2007 Share Posted January 27, 2007 The guys at the now defunct Temple Laughaurne Motorsport were built a Supra for drifting. I heard they gave up as it was not competitive enough incomparison with 200SX. £/lb you'll need a good base car to work on especially if money is tight. Ask yourself are you actually going to enter drift competitions or just pose around in a drift car on a Saturday night? Link to comment Share on other sites More sharing options...
bondango Posted January 27, 2007 Share Posted January 27, 2007 The guys at the now defunct Temple Laughaurne Motorsport were built a Supra for drifting. I heard they gave up as it was not competitive enough incomparison with 200SX. £/lb you'll need a good base car to work on especially if money is tight. Ask yourself are you actually going to enter drift competitions or just pose around in a drift car on a Saturday night? Think the Cars being built for the Paris tuning show then being used for the Euro ProDrift series http://www.prodriftseries.com/ Link to comment Share on other sites More sharing options...
Joe. Posted January 27, 2007 Author Share Posted January 27, 2007 The guys at the now defunct Temple Laughaurne Motorsport were built a Supra for drifting. I heard they gave up as it was not competitive enough incomparison with 200SX. £/lb you'll need a good base car to work on especially if money is tight. Ask yourself are you actually going to enter drift competitions or just pose around in a drift car on a Saturday night? Ive looked into it alo and came across two mkiv , an auto n/a aeo and a 95 tt man hard top , if I told you what the two cars stand me you wouldnt belive me , I bought the two of the for the price of a corolla gt shell .. if you wana have a guess at how much that was As for drifting .. Ive been a part of drifting since day one, about 4 years now, and drifting and building drift cars its all ive done for the past 2 years . Link to comment Share on other sites More sharing options...
Kranz Posted January 28, 2007 Share Posted January 28, 2007 if I told you what the two cars stand me you wouldnt belive me .. Go on then.... surprise us Link to comment Share on other sites More sharing options...
Joe. Posted January 29, 2007 Author Share Posted January 29, 2007 If I said €3000 , what would you say .. Hope this dont dammage my resale value ha Link to comment Share on other sites More sharing options...
