nige Posted January 26, 2007 Share Posted January 26, 2007 Hi guys, where do you guys buy the above fluid?and what it the best to go for? and price per litre,and how many litres for a full bleed and change,thanks. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 26, 2007 Share Posted January 26, 2007 Last time i got some from Halfrouds, but you should be able to get it from most motor factors, think i paid about £6 a lt but it should be less now, think at a guess you would need 2lt. Link to comment Share on other sites More sharing options...
Chiefgroover Posted January 26, 2007 Share Posted January 26, 2007 NEVER put silicone fluid in a supra. Well OK if you like a crap feeling pedal. Toyota also state never to use it in their ABS systems also (quote from Uk owners manual). Link to comment Share on other sites More sharing options...
Ian W Posted January 26, 2007 Share Posted January 26, 2007 i've enough for a full change if you want it Nige. £5 a bottle for Motul RBF600 as recommended by Chris Wilson. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 26, 2007 Share Posted January 26, 2007 DOT 5.1 is not silicone fluid. Link to comment Share on other sites More sharing options...
merckx Posted January 26, 2007 Share Posted January 26, 2007 DOT 5. is not silicone fluid. You forgot the "1". Dot 5 is the stuff to avoid as it's silicone based. Dot 5.1 is fine. Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 26, 2007 Share Posted January 26, 2007 You forgot the "1". Dot 5 is the stuff to avoid as it's silicone based. Dot 5.1 is fine. oops! Link to comment Share on other sites More sharing options...
supra matt Posted January 26, 2007 Share Posted January 26, 2007 i just brought some of this tonight halfords own cost £9.99 a liter! fitting my uk breaks tomorrow . Link to comment Share on other sites More sharing options...
