Ian C Posted January 26, 2007 Share Posted January 26, 2007 At least the stock rail is a known good quality item and won't piss fuel all over the place like some of the so called 'upgraded' fuel rails. (Ask Tannhäuser and JamieP about that) All the quality in the world won't get past fitment issues. I don't think we should confuse the issue and immediately write off aftermarket fuel rails as sieves just because of one isolated incident. Cliff's was an O-ring issue from what I recall. Anyway, what's this techtom thing then? -Ian Quote Link to comment Share on other sites More sharing options...
Guest Usmann A Posted January 26, 2007 Share Posted January 26, 2007 IIRC, its a eprom of some kind, used to manipulate the numbers in the stock ecu, kind of a crack for it, then they give basmaps for certain specifications. http://suprasonic.org/sonictech/techtom/ Quote Link to comment Share on other sites More sharing options...
Guest s13eater Posted January 26, 2007 Share Posted January 26, 2007 well done, i heard it was ballistic. Quote Link to comment Share on other sites More sharing options...
Wez Posted January 26, 2007 Share Posted January 26, 2007 My fuel system is stock apart from the injectors and pump and its coping happily with what I am chucking its way at the moment. Will see how it handles more boost at the next mapping session. Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 26, 2007 Share Posted January 26, 2007 Well let's ease down a bit on the doom and gloom to start with So it's a big turbo and big injectors but a stock rail with a stock FPR (running at ? psi pressure) and the pulsation dampener is still in place? And this techtom thing is a remapped ECU - thought impossible but I also recall hearing of this TechTom thing as well, it's a daughterboard in the ECU, soldered in place. As to how flexible it is I don't know. Just how sizeable is this turbo then...? If you can't richen the mix up then either your injectors are at 100% duty (!) or, if they aren't, the fuel pump is out of flow capacity. It's also possible that there is a restriction in the system somewhere that's causing a dropoff of fuel delivery... -Ian Quote Link to comment Share on other sites More sharing options...
Wez Posted January 26, 2007 Share Posted January 26, 2007 800cc injectors should not be maxed out at approx 500hp though. The other thing that caught my attention is that he only gained 25hp from a .2bar increase in boost on a large turbo, that doesnt sound right. Quote Link to comment Share on other sites More sharing options...
Homer Posted January 26, 2007 Share Posted January 26, 2007 From a recent XS Power add for the GT45: Turbine Wheel: ( GT45 SPEC ) Exducer: 3.05" (77mm) Mayor : 3.46" (88mm) Compressor Wheel: ( GT COMPETITION ) Exducer: 2.56" (65mm) Mayor : 3.90" (99mm) Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 26, 2007 Share Posted January 26, 2007 Ah, I didn't realise it was an XS power device. Mmmm. -Ian Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 26, 2007 Share Posted January 26, 2007 All the quality in the world won't get past fitment issues. I don't think we should confuse the issue and immediately write off aftermarket fuel rails as sieves just because of one isolated incident. Cliff's was an O-ring issue from what I recall. Anyway, what's this techtom thing then? -Ian Yea mine seems fine now but it does worry me a tad that it might leek again. Quote Link to comment Share on other sites More sharing options...
Wez Posted January 26, 2007 Share Posted January 26, 2007 Always carry a fire ext just in case. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 26, 2007 Share Posted January 26, 2007 Yea i have a 4kg one now;) Quote Link to comment Share on other sites More sharing options...
Guest Usmann A Posted January 26, 2007 Share Posted January 26, 2007 TBH, only ever time ive had fuel leaks were due to improper installation alot of the times the o rings get pinched when pushing into the rail. ( vasaleine works ) I got a PHR rail, beeneees. just becuase BP was upped by .2bar, and the motor made 25hp, could be down to him not being at MBT or quite a few other factors. Like peeps say,check the commons culprits in your fuel system, before you look at the EMS. Can i ask, did anyone finetune the Techtom,or did u just clip n run with it? Quote Link to comment Share on other sites More sharing options...
cleland Posted January 26, 2007 Author Share Posted January 26, 2007 The techtom software was spot on, its not piggy back its software that allows you to run the standard ecu, it cost a fortune to get it originally, so not many people are clued up with it. My original question was only advise on the fueling, as the spec on my engine is temporary and if i could run 1.4-1.6bar at a good a/f figure it would do till my new engine is built. So really it is just a test n see. Quote Link to comment Share on other sites More sharing options...
Wez Posted January 26, 2007 Share Posted January 26, 2007 Is that an FCD in there as well? Quote Link to comment Share on other sites More sharing options...
cleland Posted January 26, 2007 Author Share Posted January 26, 2007 Is that an FCD in there as well? No wez, the standard ecu is still in sittu with the fcd both not connected. The new ecu is just loose. Quote Link to comment Share on other sites More sharing options...
Guest mr2lover Posted January 29, 2007 Share Posted January 29, 2007 TBH, only ever time ive had fuel leaks were due to improper installation alot of the times the o rings get pinched when pushing into the rail. ( vasaleine works ) YOU DONT WANNA use vaseleine it eats rubber and cause u problems in future Quote Link to comment Share on other sites More sharing options...
Guest Usmann A Posted January 30, 2007 Share Posted January 30, 2007 it actually dissolves, AFAIK its petroleum jelly? I used it on every fitting i hadto makeup, and after 3 years or so touch wood hasnt leaked anywhere. Quote Link to comment Share on other sites More sharing options...
