Dash Leds / Where to get these
swandip
around the 7000mcd area. angle is not too important as most of the LED are paired up i.e dash cluster. or used in singles
"tankIE not elecIE Si, youve lost me there mate
Would you not need all those bright dashboard lights on a dimmer switch ? all that light shining into your eyes when you're trying to see whats happening in the black dark outside may be a problem
get some brighter head lights then :D
was thinking about that too, when you turn on the lights will they dim abit or be able to use the dimmer switch?
