Gee Posted January 24, 2007 Share Posted January 24, 2007 I have just had a brand new RPS Cyn R G lightened flywheel and RPS Sport Street clutch fitted on mt TT 6 speed. I have searched and found that a rattly noise is common at idle but the noise Im experiencing is whilst driving. When I press the accelerator I get a loud mechanical rattle from the gearbox/clutch/flywheel area which then dissapears at certain revs. The Gearbox oil was replaced with Toyota V160 and all bearings were replaced also. The clutch and gearbox engage fine and smooth but Im concerned about the noise. What could this be? Is it just a case of the new components bedding in? Link to comment Share on other sites More sharing options...
dan4 Posted January 24, 2007 Share Posted January 24, 2007 up to what revs are you getting the noise? Link to comment Share on other sites More sharing options...
NUTKIN Posted January 25, 2007 Share Posted January 25, 2007 If i were u i would ring the garage an get them to sort it out cause if its broken or not fitted right u dont want to know the damage it can cause the gearbox Link to comment Share on other sites More sharing options...
Pig Posted January 25, 2007 Share Posted January 25, 2007 It depends, alot do experience a rattling noise at idle Link to comment Share on other sites More sharing options...
Gee Posted January 25, 2007 Author Share Posted January 25, 2007 Has anyone else experienced anything like this? Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 25, 2007 Share Posted January 25, 2007 Get used to it, that's how they are, and why Toyota paid LUK a fortune to design a dual mass flywheel to enable them to run an undamped (stronger and more reliable) clutch plate. It WILL cause more transmission wear, but shouldn't kill it. Link to comment Share on other sites More sharing options...
TRD3000GT Posted January 25, 2007 Share Posted January 25, 2007 Yep as Chris Wilson said. Get used to it.. Mine makes the same noise with the clutch upgrade and I just live with it now.. Makes the Getrag sound more agricultural that normal. Link to comment Share on other sites More sharing options...
MrHanky Posted January 25, 2007 Share Posted January 25, 2007 Yep as Chris Wilson said. Get used to it.. Mine makes the same noise with the clutch upgrade and I just live with it now.. Makes the Getrag sound more agricultural that normal. Exactly what I would describe it as. I had both of these parts fitted yesterday and noticed it straight away. Its only usually when you are trying to accelerate at low revs I find. Mark Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 25, 2007 Share Posted January 25, 2007 It's harmonics going through the gear train making the gears and propshaft vibrate and chatter. The dual mass flywheel dampens these out. Link to comment Share on other sites More sharing options...
Gee Posted January 25, 2007 Author Share Posted January 25, 2007 Thats fine,thanks for the info guys I was just worried that I had a problem. I'll learn to live with the noise. Link to comment Share on other sites More sharing options...
