Running Diesel On Vegetable Oil Pikey Or Genius
NUTKIN
My friend has a turbo diesel 306 an he's running it on 50/50 diesel an veg oil but even after all my slating of him i drove it last night an it actually runs better i need to know peoples veiws on this.
Its not fair im running the supra an its costs me a fortunes i dont get no cheap option im not happy.
/vbb/images/smilies/bbcode_angry.gif
:blink: don't you have to have like a preheater to this the oil or something like that? 50/50 mix in summer sounds about right :) ... what about winter? :D
No, if it is 50/50 mix, there is no real winter in England anyway, but it is good to heat oil to temperature around 80-90 degrees and then cool it down before adding to fuel. Used stuff is generally better (if filtered properly ;) )
Most veg kits, contain heaters... The proper kits still have a small diesel tank to start the car with. Using the heater matrix system, they heat the oil in the tank, and once it is up to running temp, then it swaps over to the veg oil.
Veg oil is too thick at low temp and it can/will block up filters/injectors..
Because used oil is not that thick like fresh one. Also contains less water.
I am afraid this is wrong. Used oil contains water, loads of it. As well as carbons and all other manner of stuff you don't want. This is why WVO is treated the way it is. First it is warmed to seperate the water, the oil rises and then the water is drained. Most people who do this use a baby burco type of heater, then you can just open the tap and get rid of the water. Evertime you cook in oil moisture comes out of the food and gets left in the oil. This is why dirty oil always gives off steam when boiled and clean gives of only a fraction.
Wasn't there something on this a while back that said that the vegtable oil actually damages the engine overtime although it seems to act/perform ok?. Something about clogging certain parts of the engine up? - sounds like a great cheap idea :-)
Maybe i could mix screenwash they sell in aldi's with super unleaded? - I mean that stuff's pretty potent ;-)
you gotta be carefull with what car u get, any car with a bosch pump will run 50/50 + pretty much all the time, its only the lucas pumps you have to be carefull of ......... apparently
Yep that's correct, Lucas/CAV pumps dont like it at all. Been running various engines on veg oil for a while now and certain types of pumps don't like it but others can cope with up to 100% all the time. Have a mate in Romania who grows fields of sunflowers for his bees and also runs his Mk1 Golf on the oil they produce. Compare that with a Uno I tried it on here and the pump gave up pretty quickly using pre heater and SVO/Diesel mix in conjunction with a pre heater. At the moment though am using a Corsa diesel and before that had a Nova diesel. Both with the Isuzu engine and they run on SVO with just a pre-heated filter. Used Merc vans with no probs. and when I worked and lived in South West Romania I ran a 3 litre Nissan Patrol for ages on all sorts of rubbish and apart from the banjo joint filter in the pump inlet waxing in extreme cold I had no probs. The guy I sold it to before I left still runs the same engine now in a agricultural machine 5 years on.
