Supra-Dupra Posted January 23, 2007 Share Posted January 23, 2007 Hey, my friend wants to know is there much difficulty in changing from a standard smic to a fmic (xs power one), anything to be moved/replaced etc? hes puttin a do luck front on too instead of standard bumper. thanks Quote Link to comment Share on other sites More sharing options...
silvershark44 Posted January 23, 2007 Share Posted January 23, 2007 I believe you need a front mount fitting kit, which is basically the pipes to connect everything up with as everything is in a new place now obviously. Your friend may or may not have these yet. Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted January 23, 2007 Author Share Posted January 23, 2007 i think he has the hard pipe kit and all the fittings needed yea Quote Link to comment Share on other sites More sharing options...
Ric Posted January 23, 2007 Share Posted January 23, 2007 power steering cooler perhaps and to relocate the overflow tank Quote Link to comment Share on other sites More sharing options...
Scoboblio Posted January 23, 2007 Share Posted January 23, 2007 If he has an active spoiler, that will need to be removed too (at least the motors of it). Quote Link to comment Share on other sites More sharing options...
boromfccup Posted January 23, 2007 Share Posted January 23, 2007 can you buy ps cooling pipe to relocate them, or would you need to if just fitting a 76mm wide fmic Quote Link to comment Share on other sites More sharing options...
Supra-Dupra Posted January 27, 2007 Author Share Posted January 27, 2007 soo basically its straight fwd enough but the overflow tank needs relocating!? Quote Link to comment Share on other sites More sharing options...
Homer Posted January 27, 2007 Share Posted January 27, 2007 soo basically its straight fwd enough but the overflow tank needs relocating!? Fairly, provided the hard pipe kit lines up. Was it made for the XS kit? If not then you may well have problems. The PAS line might not need changing with the 76mm (2 row) IC, but you will need to relocate the expansion tank. Easiest thing is to go to a breakers and find a small one off something like a Corrolla. A small slim tank is what you need as it should fit alongside the battery nicely. Quote Link to comment Share on other sites More sharing options...
