jaymdee Posted January 23, 2007 Share Posted January 23, 2007 70 miles from Warminster to Bristol. Have they moved it? NO? 70 miles (I think) from Cobham to Warminster. Quote Link to comment Share on other sites More sharing options...
Rob Posted January 23, 2007 Share Posted January 23, 2007 IF your yellow light comes on, and you pull into SHELL SERVICE STATION, YARM, CLEVELAND, you can still get 70.4 litres into the tank. Now that's what I call service. Once again that's SHELL SERVICE STATION, YARM, CLEVELAND, putting a pint into a half-pint pot since 1973. Quote Link to comment Share on other sites More sharing options...
lui Posted January 23, 2007 Share Posted January 23, 2007 I never let my tank go below 3/4 or a 1/2 at the bar minimum unless I really have to. A full tank of petrol just seems like a much better and responsive drive to me! Same here just makes it a lot cheaper when you fill up Quote Link to comment Share on other sites More sharing options...
Ian W Posted January 23, 2007 Share Posted January 23, 2007 Another reason for not letting it get that low is to prevent sucking all that tank sediment and clogging up your filters. there shouldn't actually BE any tank sediment in the tank as i believe the Supra's tank is plastic and therefore doesn't corrode at all. Quote Link to comment Share on other sites More sharing options...
Mike B Posted January 23, 2007 Share Posted January 23, 2007 IF your yellow light comes on, and you pull into SHELL SERVICE STATION, YARM, CLEVELAND, you can still get 70.4 litres into the tank. Now that's what I call service. Once again that's SHELL SERVICE STATION, YARM, CLEVELAND, putting a pint into a half-pint pot since 1973. Classic - that's my local fill-up!! It's amazing how much fuel you can get in when your local vpower station is 10 miles away. here I was think I was just a natural at getting 80lt in a 70lt tank, turns out I've just been plain cheated:tongue: Quote Link to comment Share on other sites More sharing options...
Guest ColB Posted January 23, 2007 Share Posted January 23, 2007 If there was any sediment or other muck in the tank it would likely sink, so go through pump anyway, regardless of full or empty... 1/4 line as empty is no good to me.. only takes 2 1/2 days to get there. get a full 3 days return trip to work if go to the light Quote Link to comment Share on other sites More sharing options...
Graham S Posted January 23, 2007 Share Posted January 23, 2007 Ok guys check this.. I've had 82 litres in my tank before! that ws JUST short of 80 quid! Quote Link to comment Share on other sites More sharing options...
TrickTT Posted January 24, 2007 Share Posted January 24, 2007 there shouldn't actually BE any tank sediment in the tank as i believe the Supra's tank is plastic and therefore doesn't corrode at all. I agree. when i changed my fuel pump last year, the inside of the tank was spotless. Quote Link to comment Share on other sites More sharing options...
tbourner Posted January 24, 2007 Share Posted January 24, 2007 Also, that's what the filter's for anyway, why worry about sediment getting in? It's not like it'll EVER clog it to the point that not enough fuel can get through is it (well unless you pour sand in the filler). It's not an air filter!! I never filled my Supe up fully I don't think, only ever put in £25 at a time, and waited for it to get at least below 1/4 line before going back. Mainly because it's a bloody heavy tank when full! Quote Link to comment Share on other sites More sharing options...
