Oil Filler cap
dave barratt
I have a Blitz oil cap that I took off my car because it was leaking slightly under full chat. It could have been my rocker cover though because my new cap also leaks ever so slightly so I would assume that it was in fact my rocker cover and not the cap that was causing the slight leakage.
You are welcome to try it out on your car if you like. I would like £15 for it and if it leaks for you then you can return it to me for a full refund.
Picture is borrowed from MVP
