Speedo conversion
Guest JesperDJ
Guest JesperDJ
Hi
My supra is fitted with a 180km/h speedometer, can i chance that to another showing higher speed, just by changing the speedo part to another one from another car?, or does it require some sort of electronic speed converter gadget?
- or what is my options?
Sounds like you want to do the opposite to me!! I have the 320 km/p speedo and want to change to the 180 version.... as far as I understand it what you will need to find is the 320 speedo mechanism which would include the needle and it's spindle, this way your speedo conversion says the say but the increments get small.... you would obviously then need the 320 face.
Good Luck
