tomssupra Posted January 23, 2007 Share Posted January 23, 2007 Hi, Does anyone know if you can get the Rota GTR rims with a Dish, maybe 1" or something? Which offset would I ask for here? Thanks, Quote Link to comment Share on other sites More sharing options...
fredm Posted January 23, 2007 Share Posted January 23, 2007 Hi, you will probably find the info your after by speaking directly to one of the many traders on here, Pro-alloys, Sumo, Whifbitz, Envy etc. etc. etc. etc. etc. Quote Link to comment Share on other sites More sharing options...
Ian W Posted January 23, 2007 Share Posted January 23, 2007 i don't think you can mate. however they do come in different widths (basically the spokes recess more creating a concave look). tdR has some on his car and they look VERY nice with the deeper rim on the back. check them out Quote Link to comment Share on other sites More sharing options...
GetawayDriver Posted January 23, 2007 Share Posted January 23, 2007 i have a set of rota GTR's on my supra, the fronts and rears have different offsets and so a different 'dish' as you call it. on the rear the spoke dish in towards the hub quite a lot with quite a wide lip on the rim, on the fronts the spokes are pretty much flat with no lip. you can't fit wider wheels to the front without spacers or clearance problems or both. i wouldn't get them from rarerims.co.uk though. they sent me the wrong wheel nuts for a supra and when i fitted them with a ratchet gun and trashed two hubs worth of studs they just laughed when i called them to complain. great customer service. i'll try get a pic so you can see what they look like on the car. the sizes you need for a supra are Front - 18x8.5 5x114.3 PCD 40 ET (double check the offset for the front, not sure about this one) Rear - 18x9.5 5x114.3 PCD 30 ET added a picture. wheels look shit with suspension too high and that nose cone. lowered it more with a stock front end now and wheels look great. i went for the silver with a polished lip. Quote Link to comment Share on other sites More sharing options...
rik Posted January 23, 2007 Share Posted January 23, 2007 Rota GTR's are probably the only wheels i would consider coughing up for. I like them a lot Quote Link to comment Share on other sites More sharing options...
Shilakadaddy Posted January 24, 2007 Share Posted January 24, 2007 afaik the only offset options for these wheels are: Front - 18x8.5 ET25 or ET35 (I'd go for ET25, as I have ET35 and I think they looked a little too 'tucked in') Rear - 18x9.5 ET30 http://www.mkivsupra.net/vbb/vbpgimage.php?do=full&p=4614&d=1163686227 Quote Link to comment Share on other sites More sharing options...
Rayman Posted January 24, 2007 Share Posted January 24, 2007 Im tempted by these but am unsure whether they would be ok on stock suspension without rubbing, ive heard of them rubbing on lowered ride height. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 10, 2007 Share Posted February 10, 2007 Been looking at these myself, are you sure that you cant get the 18"x9.5 30 offset on the front? as they look like they would have the Clearance for UK brakes? Quote Link to comment Share on other sites More sharing options...
Nic Posted February 10, 2007 Share Posted February 10, 2007 http://www.rotawheelsuk.com/ Quote Link to comment Share on other sites More sharing options...
GetawayDriver Posted February 10, 2007 Share Posted February 10, 2007 i have a uk spec. the fonts are 18x8.5 and clear the brakes fine. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 10, 2007 Share Posted February 10, 2007 What is the offset on the 18x8,5? i was hoping to be able to get the 9,5 on, but they only come in 30 offset so i don't know if they will clear the arches, or take a 235-245 tyre. Quote Link to comment Share on other sites More sharing options...
GetawayDriver Posted February 10, 2007 Share Posted February 10, 2007 you can't get a 18x9.5 on the front. offset is way out. it would almost stick out past the arch. also when you turn the wheel it would hit the inner arches too. if you look at the rotas for the supra the fronts and rears are so different they only just look like they are the same wheel. Quote Link to comment Share on other sites More sharing options...
Pig Posted February 10, 2007 Share Posted February 10, 2007 Anyone know a price on them? I really like them! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 10, 2007 Share Posted February 10, 2007 Just been looking at a set on a friends Skyline, he has 18x9.5 30 offset all round, the Skyline needs an offset of around 15-20, so the 30 sits farther inboard, i was going by the std 17" Supra wheels being 9" wide and the offset being 40 ish? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 28, 2007 Share Posted February 28, 2007 you can't get a 18x9.5 on the front. offset is way out. it would almost stick out past the arch. also when you turn the wheel it would hit the inner arches too. if you look at the rotas for the supra the fronts and rears are so different they only just look like they are the same wheel. Just resurrecting this as i have just found out that Rota now do the 9.5x18" in 12,20 and 30 offsets so do you think the 20 offset would fit? unfortunately not had a chance to try my mates Rotas yet. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 28, 2007 Share Posted February 28, 2007 Just resurrecting this as i have just found out that Rota now do the 9.5x18" in 12,20 and 30 offsets so do you think the 20 offset would fit? unfortunately not had a chance to try my mates Rotas yet. +20 offset will stick out even futher past the wheel arches than +30. Quote Link to comment Share on other sites More sharing options...
Nic Posted February 28, 2007 Share Posted February 28, 2007 Dick, this offset calculator should help you compare to stock wheel widths/offsets. Basically a 9.5" width + 20 offset would stick out 49mm wider than stock wheels. http://www.1010tires.com/WheelOffsetCalculator.asp Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 28, 2007 Share Posted February 28, 2007 Thanks Nic, bit of an awkward one as my Ray's wheels are 9x18 and i think the offset is 38 (have to check) but according to the calculator if i was to put 9.5x18 with 30 offset they would only project an extra 14mm, maybe i should just wait until i can try my mates wheels, although i did find this link http://www.rotawheels.com/p45r.php that seems to say that the GTRs come in a 35 and 48 offset but they are not labelled as GTRs and may also not be available in the UK:( Quote Link to comment Share on other sites More sharing options...
alan_blue Posted February 28, 2007 Share Posted February 28, 2007 so will the extra 49mm rub then? Quote Link to comment Share on other sites More sharing options...
Nic Posted February 28, 2007 Share Posted February 28, 2007 so will the extra 49mm rub then? Yes I would think so 49mm Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 28, 2007 Share Posted February 28, 2007 so will the extra 49mm rub then? Where do you get the extra 49mm?? Quote Link to comment Share on other sites More sharing options...
cleland Posted March 1, 2007 Share Posted March 1, 2007 This is a rota gtr rim 9.5x18 with 20 offset from my skyline, i tryed it on the supra to see how it looked and it sticks out a good 2 inch to much, but the dish suited the front. Quote Link to comment Share on other sites More sharing options...
imi Posted June 23, 2007 Share Posted June 23, 2007 I like these wheels. Wonder whether the gunmetal version is better suited for a Black Supra as supposed to the silver one? Quote Link to comment Share on other sites More sharing options...
hoff Posted June 23, 2007 Share Posted June 23, 2007 I love these and have been tempted to get the black one with the red lip but am unsure on my black supe even after G-NEMIE di a photoshop http://www.mkivsupra.net/vbb/showthread.php?t=113380 They're so gorgeous in the fesh but dont know if they suit or not. Quote Link to comment Share on other sites More sharing options...
lockys96 Posted June 24, 2007 Share Posted June 24, 2007 they are not dish wheels. lower offsets are made by the wheel design tapering out. if they had a 1" dish they would prob be around 18 offset Quote Link to comment Share on other sites More sharing options...
