Guest dave bryant Posted January 22, 2007 Share Posted January 22, 2007 Hi ive just got my first supra mkiv, im having a few teething probs can anyone help my car is an auto i have fitted a speedo convertor that works fine the thing is supposed to delimit as well but the car redlines at 120mph ithought they should go faster than that? any ideas???? Quote Link to comment Share on other sites More sharing options...
Guest dave bryant Posted January 22, 2007 Share Posted January 22, 2007 also is there anyone from the south of hampshire that is on this site:) Quote Link to comment Share on other sites More sharing options...
Ian W Posted January 22, 2007 Share Posted January 22, 2007 you sure that your particular convertor is also a delimiter? (i.e. is it actually hitting the redline?) where did you get it from? Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted January 22, 2007 Share Posted January 22, 2007 Hi ive just got my first supra mkiv, im having a few teething probs can anyone help my car is an auto i have fitted a speedo convertor that works fine the thing is supposed to delimit as well but the car redlines at 120mph ithought they should go faster than that? any ideas???? Hmm weird....sounds like your box is slipping by the sounds of it...how many miles are on the box? is it ok from low revs, midrange etc? I know this sounds really stupid and im not being patronising in any way but is your overdrive engaged?? Quote Link to comment Share on other sites More sharing options...
juanchan Posted January 22, 2007 Share Posted January 22, 2007 Welcome to the forum. Can't help you with the convertor/delimiter issue but I do know that there's a fair few of us in Hampshire Quote Link to comment Share on other sites More sharing options...
Guest dave bryant Posted January 22, 2007 Share Posted January 22, 2007 i bought the convertor from ebay i have used them before with no problems, the car is redlining its like there are only 3 gears if that makes sense apart from that no problems whats the buttons around the box for ie manu and od could these be stopping the top speed or does anyone think the delimitor is not there?? like i say the car redlines at 120ish mph but it gets there fu*king fast:D :D Quote Link to comment Share on other sites More sharing options...
Guest dave bryant Posted January 22, 2007 Share Posted January 22, 2007 hi where in hampshire? Quote Link to comment Share on other sites More sharing options...
Ian W Posted January 22, 2007 Share Posted January 22, 2007 sounds like you have it in manu mode or have the o/d switched off as has been said. Quote Link to comment Share on other sites More sharing options...
bowk1uk Posted January 22, 2007 Share Posted January 22, 2007 your overdrive is on its the button on the right side of your gear stick there should be a yellow light on your dash when its engaged turn this off you will have 4 gears Quote Link to comment Share on other sites More sharing options...
Guest dave bryant Posted January 22, 2007 Share Posted January 22, 2007 there are no lights on the dash to say they are off i have pressed them all and it makes no difference:search: is there an easy test may be a sensor is broke Quote Link to comment Share on other sites More sharing options...
Ian W Posted January 22, 2007 Share Posted January 22, 2007 your overdrive is on its the button on the right side of your gear stick there should be a yellow light on your dash when its engaged turn this off you will have 4 gears actually the yellow light is on when overdrive is OFF (disengaged). the overdrive should usually be on as this IS the 4th gear Quote Link to comment Share on other sites More sharing options...
Guest dave bryant Posted January 22, 2007 Share Posted January 22, 2007 my overdrive button is on the dash light is off maybe the overdrive is broke?? Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted January 22, 2007 Share Posted January 22, 2007 there are no lights on the dash to say they are off i have pressed them all and it makes no difference:search: is there an easy test may be a sensor is broke Its on the right hand side of your auto lever under the big button? the little one underneath needs to be clicked in, this will give you the 4th gear Failing that then if its red lining at 120 there may be problems with the transmission Quote Link to comment Share on other sites More sharing options...
Guest dave bryant Posted January 22, 2007 Share Posted January 22, 2007 do you think this could be electrical when driving you turn the od on and off the revs do move about depending on what is selected so the button does something Quote Link to comment Share on other sites More sharing options...
bowk1uk Posted January 22, 2007 Share Posted January 22, 2007 actually the yellow light is on when overdrive is OFF (disengaged). the overdrive should usually be on as this IS the 4th gear oops wrong way round Quote Link to comment Share on other sites More sharing options...
Guest dave bryant Posted January 22, 2007 Share Posted January 22, 2007 does 3rd gear redline at 120ish??? is there an easy fix?? Quote Link to comment Share on other sites More sharing options...
mikeyb10supra Posted January 22, 2007 Share Posted January 22, 2007 do you think this could be electrical when driving you turn the od on and off the revs do move about depending on what is selected so the button does something Leave it clicked in and try again Quote Link to comment Share on other sites More sharing options...
Guest dave bryant Posted January 22, 2007 Share Posted January 22, 2007 also i want a fat number plate not my square one at the rear where can i get one:rolleyes: Quote Link to comment Share on other sites More sharing options...
bowk1uk Posted January 22, 2007 Share Posted January 22, 2007 i would say around 110 maybe you have a faulty overdrive, button not sure mate Quote Link to comment Share on other sites More sharing options...
Guest dave bryant Posted January 22, 2007 Share Posted January 22, 2007 done that today with the wife following in the subaru Quote Link to comment Share on other sites More sharing options...
mr lover Posted January 22, 2007 Share Posted January 22, 2007 3rd gear would go faster than 120 without redlining Quote Link to comment Share on other sites More sharing options...
Guest dave bryant Posted January 22, 2007 Share Posted January 22, 2007 i would say around 110 maybe you have a faulty overdrive, button not sure mate but when i press the button the revs increase slightly and drop when its engaged:search: Quote Link to comment Share on other sites More sharing options...
Guest dave bryant Posted January 22, 2007 Share Posted January 22, 2007 3rd gear would go faster than 120 without redlining maybe the speedo is slightly out and the delimitor is not working Quote Link to comment Share on other sites More sharing options...
bowk1uk Posted January 22, 2007 Share Posted January 22, 2007 can you hear it change gear when you press the buton if you can hear it change gear its working fine , and your dash light is out Quote Link to comment Share on other sites More sharing options...
Guest dave bryant Posted January 22, 2007 Share Posted January 22, 2007 not sure thinking about it i should count the gears Quote Link to comment Share on other sites More sharing options...
