Common part numbers
Lewis
I was thinking of somehow listing the most common parts from the epc.
Originally I was going to convert the epc to php and allow it to be queried but I think this may be too much work for little gain.
I haven't decided what to do with it yet but i will do something.
What are the most commonly requested part/#'s ?
J spec Turbo FR 17201-46021
J spec Turbo RR 17208-46021
Intercooler 17940-46070
Oil pump 15100-46052
Water pump 16100-49846
Gasket set 04111-46094
Cam belt 13568-49036
Lexus V8 oil filter 90915-20004
Standard Oil filter 90915-20003
Gskt, drain plug 90430-12031
Air filter 17801-46060
UK Left Rear Disk 42431-14150
UK Right Rear Disk 42431-14150
UK Left Front Disk 43516-14030
UK Right Front Disk 43512-14200
UK Left Rear Calliper 47750-14280
UK Right Rear Calliper 47730-14270
UK Left Front Calliper 47750-14270
UK Right Front Calliper 47730-14260
UK Brake Pads Front (both) 04465-14150
UK Brake Pads Rear (both) 04466-14040
UK Shim kit rear 04946-14030
UK Shim kit front 04945-14110
UK Fitting kit rear 04948-14010
UK Fitting kit front 04947-14010
Stock 17” wheels - Front 42611-1B050 (subs -1B090)
Stock 17” wheels - Rear 42611-1B060 (subs -1B100)
Centre caps - Old style (Need 4) 42603-14320
GS300 sport wheel - Front PZ439-S0670-ZM
GS300 sport wheel - Rear 01700-00003
Front Bilstien shock 48510-09015
Rear Bilstien shock 48530-09015
Engine undertray 51440-14010
Clip (need 5) 90119-06354
Bolt (need 6) 90159-50311
Nut (need 6) 90179-05060
Inlet no1 17751-46050
UK Spec injectors
Injector 550cc (each) 23209-49035
Fuel pump 23221-46110
Resistor pack 28510-46020
3 dial Meter ring - (Japan only part) 08172-14020
Celica/Clear side repeaters (2 of each)
Lamp Assy, side turn signal 81731-20220
Indicator bulb 12v 5w 90981-15012
Turn signal gasket 81732-20220
Facelift front indicators
Lamp Assy, front turn signal RH 81510-80086
Lamp Assy, front turn signal LH 81520-80086
Front Headlamp (facelift) 81150-1B231
Front Headlamp (facelift) 81110-1B231
Rear lights (facelift) 81560-14700
Rear lights (facelift) 81550-14700
Floor mats-Black with grey 00008-22003-01
Autobox fluid “Toyota Type T-IV ATF Fluid" (4L tin) 08886-81015
