TMS Sway Bars
Paul Laing
Whats your views on these? TMS Sway bars
__________________________________________________
These bars weigh 15 pounds for both of them they are made of chromoly with only the newest technology available.
The Front Bar specs are as follows (note these #'s are measured by the stiffness of the existing TRD sway bars that you can get from TRD)
Front Sway Bar (2 way adjustable)
Light Setting 8% stiffer then TRD 498.9 lbs/in
Heavy Setting 27% stiffer than TRD 584 lbs/in
Rear Sway Bar (3 way adjustable)
Light 18% softer then TRD 367 lbs/in
Medium 6% Stiffer than TRD 458 lbs/in
Heavy 35% Stiffer than TRD 588 lbs/in
Might buy some when i'm in Florida in July, $499 so about £250
