boombastictiger Posted January 20, 2007 Share Posted January 20, 2007 Hi, I recently got new front brake pads..After about 300 miles driving they sqeek sooo much when i brake lightly to medium!!, its so embarrasing. What can I do, when I first start the car and drive around for 5-10 mins the brakes dont make any noise, but once they heat up a bit the noise is soooo Loud!!. Braking is fine it doesnt pull to 1 side.. Please Help Link to comment Share on other sites More sharing options...
Dr_Doom Posted January 20, 2007 Share Posted January 20, 2007 Did you fit the anti-squeal shims with the brake pads? Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted January 20, 2007 Share Posted January 20, 2007 Did you fit the anti-squeal shims with the brake pads? i almost threw mine away after i fitted my pads, they look like they are part of the old brakes but you can just remove them and use them again Link to comment Share on other sites More sharing options...
boombastictiger Posted January 20, 2007 Author Share Posted January 20, 2007 im not sure, I just took the car to the garage and had the brakes changed, I gvae them the brakes though...What are anti squel shims? Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted January 20, 2007 Share Posted January 20, 2007 im not sure, I just took the car to the garage and had the brakes changed, I gvae them the brakes though...What are anti squel shims? they're just a thin plate that fit between the pads and the piston in the caliper sounds like they chucked em Link to comment Share on other sites More sharing options...
Gamer Posted January 20, 2007 Share Posted January 20, 2007 Could possibly be the pads glazing ? Give the car a few hard stops and see if it improves after that. Link to comment Share on other sites More sharing options...
Dr_Doom Posted January 20, 2007 Share Posted January 20, 2007 I'd get it checked. It's really easy to do yourself (only 2 bolts to remove the caliper) or get the garage to do it. If you find the shims are still fitted then lots of copper grease on the back of the brake pad is supposed to cure it.. You do need to put quite a bit on though.. Link to comment Share on other sites More sharing options...
Dr_Doom Posted January 20, 2007 Share Posted January 20, 2007 I'd also give the pad surface a good rubbing down with some grit paper Link to comment Share on other sites More sharing options...
boombastictiger Posted January 20, 2007 Author Share Posted January 20, 2007 Cool, ill give that a try, the anti sqeal pads wouldnt by any chance happen to be a shiny piece of metal would it, i remember there was a thin metal stripe on the back of the pad? I have 1 of the old pads spare, ill see if there is anything on there ... Link to comment Share on other sites More sharing options...
merckx Posted January 20, 2007 Share Posted January 20, 2007 You also get a wear ridge appearing, ie the pad doesn't always cover the whole of the disc so there is an area on the disc that doesn't wear down. Sometimes new pads are larger than the old ones and rub up against this unworn area on the disc resulting in a squeal. Link to comment Share on other sites More sharing options...
Chewie Posted January 20, 2007 Share Posted January 20, 2007 Try smearing Coppaslip high melting point grease on the back of the pad steel mounting plate not much as it can spread on to the friction material and disc. Link to comment Share on other sites More sharing options...
Scooter Posted January 20, 2007 Share Posted January 20, 2007 Cool, ill give that a try, the anti sqeal pads wouldnt by any chance happen to be a shiny piece of metal would it, ... yes......... also what pads are they stock? if not what brand? Link to comment Share on other sites More sharing options...
boombastictiger Posted January 20, 2007 Author Share Posted January 20, 2007 You also get a wear ridge appearing, ie the pad doesn't always cover the whole of the disc so there is an area on the disc that doesn't wear down. Sometimes new pads are larger than the old ones and rub up against this unworn area on the disc resulting in a squeal. If this is the case, what can be done? Link to comment Share on other sites More sharing options...
boombastictiger Posted January 20, 2007 Author Share Posted January 20, 2007 yes......... also what pads are they stock? if not what brand? They are allied Nippon pads, basically meant to be exactly the same as OEM pads, as this company makes them for Toyota apparently... I got them cheap £15 Link to comment Share on other sites More sharing options...
Gamer Posted January 20, 2007 Share Posted January 20, 2007 They are allied Nippon pads, basically meant to be exactly the same as OEM pads, as this company makes them for Toyota apparently... I got them cheap £15 I would not expect much from pads that cost 15 squid. Link to comment Share on other sites More sharing options...
CJ Posted January 20, 2007 Share Posted January 20, 2007 I would not expect much from pads that cost 15 squid. I agree. Of all the things to definitely not skimp on I would put brakes at the top of the list. Link to comment Share on other sites More sharing options...
boombastictiger Posted January 20, 2007 Author Share Posted January 20, 2007 The pads are meant to be exactly the same pads as you get with OEM, a trader on here was selling them a few weeks ago. I got them for £15, because I was lucky I guess, they normally cost more... Link to comment Share on other sites More sharing options...
boombastictiger Posted January 20, 2007 Author Share Posted January 20, 2007 Here we go, this is the link to the pads http://www.mkivsupra.net/vbb/showthread.php?t=80894&highlight=allied+nippon Link to comment Share on other sites More sharing options...
Gamer Posted January 20, 2007 Share Posted January 20, 2007 Fair enough, as long as you are happy with them. Did they come with ear plugs ? Just joking bud, you probably just need the shims. Link to comment Share on other sites More sharing options...
