Engine Build + 6 Speed Conversion!
Pig
Well, its been a long time coming. I have had my car off the road un-insured for about 6 months now saving (apat from jap show).
Im aiming for 500 rwhp (or not too much below), here are my plans:
Please excuse things spelt wrong as my technical knowledge is rubbish
6 speed box (rebuilt)
RPS Carbon Carbon Clutch
Chome olly lightened flywheel
ARP Bolts for fly wheel
Short Shifter
HKS DLI
AEM
AEM 3.5 bar
HKS 264 Cams
HKS 2.0mm Head gasket
ARP Studs
CP Pistons
Carillo Rods
Ferrea Valves etc
HKS 264 Cams
Oil Catch can
New Water pump
Modified Oil pump
Queit exhaust
And plenty more to come when i can afford it.
Engine is being built to handle anything i want to put through it! Want to do Billet Main jobbies but cant afford it!
Not long now though, booked in at the beginning of feb!
Any opinions appreciated!
EDIT: oops, forgot to say will be running a BL T61
Also Fuel System:
960cc Injectors
Twin Walbro Pumps
FPR
Aftermarket Fuel Rail
Braided lines
Cooling:
Greddy 3 row FMIC
Fluidline rad
Ecterior:
100% standard :eyebrows:
Exhaust:
BL4" for sale £400
HKS Ti Carbon
UPDATE:
My bits are now here and the engine will be taken out and sent off this week coming! Went to turbofit on sat and got some pics of all the goodies :D
  • Replies 82
Not sure you will hit 500 with that only... May need hybrids at the minimum... seems very similar to my build, which will start at the end of feb, except I am going for standard internals...
My other differences:
HKS Fuel system 680cc, pump, lines, rail, etc
LINK ECU (not as good as AEM, but cheaper, and just as capable)
Hybrid turbos
FMIC
Exhaust
Induction
Brake system - lines, oem discs, CW fast pads
clutch and flywheel...
Sounds good!!
would be very interesting to compare...
Where you having yours done?
Who is doing the build Jon? Good luck by the way ;)
The build will be done by Turbofit.
Hey bud, In what way are you modding the oil pump.. is this one from Dusty?
Thats correct. I fugured it wouldnt be much more for the modified one than a new stock one!
Dont suppose you have any idea on price for the new water pump?
I cant remember the exact prices but the modded oil pump was something like £500.
Hybrid turbos
FMIC
Exhaust
Induction
Sounds good!!
Updated 1st thread!
Quiet exhausts generally are more restrictive and therefore robbing power. You may wish to consider a system that gives you a more subtle exhaust note with a bung fitted and more raw power with the bung removed.
I am going to add a silencer to my 1000BHP car so I can keep the neighbours sweet and have a free flowing system with the silencer out when I need out and out power. I think when I have the silencer section made up it will take 10 -15 minutes to take out and replace, using a gun, 20 -25 with just spanners.
Can have a go at making a silencer baffel for yours mate will need the car for a day/half though. made them for my 300zx just unbolt them an pull them out.
or I can make another baffel to go in the pipe with flanges each end to allow you to bolt a straight through pipe back in
