Problem with RLTC
Greystoke
Yes I have launch control.
I don't have the digi Adjuster.
Calibrated it myself, by spinning each wheel to match it to the dat file.
It was working fine for the last couple of months.
Using tight winter dat.
If the rpm wasn’t a clean signal, could it cause this.
I don’t think it’s anything to do with the wheel sensors, as it kicks in when the car is stationary once the rpm goes above 2000rpm
http://mkivsupra.net/vbb/showthread.php?t=70087
Anything in there look like it could be the problem?
It’s not killing the engine when turning the unit from off to on.
Also it’s not a digi adjuster I have.
The RLTC works if I lose traction, but it also kicks in while the car is stationary, if I rev it above 2000rpm.
You can hear the engine getting a slight cut when doing this.
Martin and Inferno, read the thread!
This doesn't seem to have anything to do with the slip control adjustments past 22/23 initiating LC and stalling the engine! It's above 2,000 rpm he has the problem and if it was LC related, surely it would cut out.
Greystoke - PM Terminator mate or Matt Harwood.
