Guest g3dar Posted January 17, 2007 Share Posted January 17, 2007 Have a wee problem !!!! My crank pulley fell apart on the way home from work today, and destroyed the fan in the process. If anyone can help I need a fan and a pulley. I haven't got the pulley nut off yet, and think the breaker bar and starter method might be called on. I only have a 2ft breaker bar. Do you think this will be enough? Any help much appreciated. Cheers Link to comment Share on other sites More sharing options...
Scooter Posted January 17, 2007 Share Posted January 17, 2007 I haven't got the pulley nut off yet, and think the breaker bar and starter method might be called on. I only have a 2ft breaker bar. Do you think this will be enough? Any help much appreciated. Cheers in a word no! you'll need at least another tube over the top of this (scaffold pole is my weapon of choice) There is a good thread on here about changing the cambelt with details of how to remove the pulley etc...... i'll have a look for you...... Link to comment Share on other sites More sharing options...
Scooter Posted January 17, 2007 Share Posted January 17, 2007 here it is......... alot isn't relevant to just replacing the pulley but there is a need to firstly undo the nut you mention and also then to remove the inner part. there should be a fan available from someone breaking a car..... ......have a good look around to check for other damage too....... Link to comment Share on other sites More sharing options...
Jake Posted January 17, 2007 Share Posted January 17, 2007 Have a wee problem !!!! My crank pulley fell apart on the way home from work today, and destroyed the fan in the process. On the bright side, you were lucky. One guy crashed his car when the same thing happened to him last week. Apparently it left him with no power steering just as he was cornering. Link to comment Share on other sites More sharing options...
Daston Posted January 17, 2007 Share Posted January 17, 2007 I know how you feel bud this happend to me my garage said they used a hammer and chissle to get the pully off Link to comment Share on other sites More sharing options...
Guest g3dar Posted January 17, 2007 Share Posted January 17, 2007 Thanks for your response guys, think i'll just get a garage to do it. It's going in for a clutch on monday so i'll ask them to do that as well. Cheers Link to comment Share on other sites More sharing options...
Guest g3dar Posted January 17, 2007 Share Posted January 17, 2007 Just one other question. Is there a difference in pulley between the turbo and NA model? Mine is NA. Thanks again Link to comment Share on other sites More sharing options...
lui Posted January 17, 2007 Share Posted January 17, 2007 Two crank pulleys gone within one week Hope you get it sorted out soon Link to comment Share on other sites More sharing options...
Daston Posted January 17, 2007 Share Posted January 17, 2007 nope the crank pulley is the same for both SZ and TT's Link to comment Share on other sites More sharing options...
Guest g3dar Posted January 17, 2007 Share Posted January 17, 2007 Two crank pulleys gone within one week Hope you get it sorted out soon Must be the cold weather. The rubber must just be perishing. If any of you guys have a squealing fan belt like noise just now, CHECK THE PULLEY Link to comment Share on other sites More sharing options...
NUTKIN Posted January 20, 2007 Share Posted January 20, 2007 Im the one who crashed the car due to pulley coming off the pulley new from toyota is nearly £200 an i got the bolt for around £7 from my local car spares an the belt from toyota is £47 and from my local car spares £12 so big difference in prices dependin on where u go Link to comment Share on other sites More sharing options...
johnd-mkiv Posted January 20, 2007 Share Posted January 20, 2007 I have a fan mate complete £50 posted Link to comment Share on other sites More sharing options...
Guest g3dar Posted January 20, 2007 Share Posted January 20, 2007 Im the one who crashed the car due to pulley coming off the pulley new from toyota is nearly £200 an i got the bolt for around £7 from my local car spares an the belt from toyota is £47 and from my local car spares £12 so big difference in prices dependin on where u go I got an underdrive pulley from ebay for £30 and a fan from Pro Alloys for £15. All in the post. I know the issues around these pulleys but just need it back on the road ASAP! Feel pretty lucky compared to what happened to you mate. guttin! Link to comment Share on other sites More sharing options...
dan4 Posted January 20, 2007 Share Posted January 20, 2007 do you not hear these breaking up guys? Link to comment Share on other sites More sharing options...
Guest g3dar Posted January 21, 2007 Share Posted January 21, 2007 do you not hear these breaking up guys? You might here the noise but theres nothing to say you know what it is. I thought it was the tensioner pulley needing a new bearing. I had that replaced just before the crank pulley broke. I did quieten down to be fair. Link to comment Share on other sites More sharing options...
Supra_Star Posted January 21, 2007 Share Posted January 21, 2007 Nutkin had squeeling for only two days and thought also that it was the tensioner pulley. Then without any further warning off it came and off he went If you do get a second hand crank shaft pulley be very careful of the condition of it and please make sure that whoever removed it from another car did not use heat of any kind to remove the centre bolt. Oh yes and just to mention that Nutkin discovered that the bolt is NOT left hand threaded as Toyota Main Dealers said it would be Link to comment Share on other sites More sharing options...
Guest g3dar Posted January 21, 2007 Share Posted January 21, 2007 Will bear that in mind Thanks Link to comment Share on other sites More sharing options...
Jake Posted January 21, 2007 Share Posted January 21, 2007 the bolt is NOT left hand threaded as Toyota Main Dealers said it would beNo way! That's pretty poor if they told him that Link to comment Share on other sites More sharing options...
