JamieP Posted January 17, 2007 Share Posted January 17, 2007 I have a hks fuel rail with hks 1000cc injectors and its a pita and keeps leaking. When i look inside the rail it has a groove that the injector ring sits in but nothing at the bottom for the injector to pull into. If i over tighten it the injector ring pulls past the groove and it leaks.. same if i under tighten it. I get it all just right and when driving a few hundred miles it must vibrate and move the injector and it leaks again. its a royal PITA Has anyone else had this trouble with the HKS rail? i just dont understand it. Anyone got a pic of the inside of a boostlogic rail or any others? i want to see if there is a lip at the bottom that the injector pulls in against. Thanks for any help Jamie:) Quote Link to comment Share on other sites More sharing options...
Lucifer Posted January 17, 2007 Share Posted January 17, 2007 which collets did you use? Quote Link to comment Share on other sites More sharing options...
JustGav Posted January 17, 2007 Share Posted January 17, 2007 I'm running a PHR rail, I haven't seen any leakage from around the injector area, I had enough problem with the fuel-in pipes leaking in the beginning... took me ages to get it sorted. Quote Link to comment Share on other sites More sharing options...
lui Posted January 17, 2007 Share Posted January 17, 2007 Hope you get it sorted out soon mate as leaking fuel = FIRE Don't want another supra up in flames this week. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 17, 2007 Author Share Posted January 17, 2007 which collets did you use? The ones that came with it. Quote Link to comment Share on other sites More sharing options...
Lucifer Posted January 17, 2007 Share Posted January 17, 2007 and which injectors? HKS? Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 17, 2007 Author Share Posted January 17, 2007 Hks rail, hks injectors and hks collets... its not leaking now but i just know its gonna start again soon. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 17, 2007 Author Share Posted January 17, 2007 Anyone got a pic of the inside of a boostlogic rail? Quote Link to comment Share on other sites More sharing options...
Nic Posted January 17, 2007 Share Posted January 17, 2007 I've never had any problems with my HKS rail and HKS injectors, they've been on for over 5 years now. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted January 17, 2007 Share Posted January 17, 2007 I've never had any problems with my HKS rail and HKS injectors, they've been on for over 5 years now. me either. The only issue is the small neck size restricting injector selection. Jamie, are you sure you didnt pinch an O ring fitting the injectors. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 17, 2007 Author Share Posted January 17, 2007 me either. The only issue is the small neck size restricting injector selection. Jamie, are you sure you didnt pinch an O ring fitting the injectors. Ive had it out 3 times now and all the o-rings are perfect. What happens is the oring on the injector sits in the groove in the rail.. when i fit the rail and tighten it in it weeps alittle at the manifold end... if i tighten it to much then the oring pull past the groove and it pisses out. What im wondering is if the boostlogic rail has i lip to stop the oring pulling past... then in that case i can tighten it down with out risking it pulling past. Quote Link to comment Share on other sites More sharing options...
Ian W Posted January 17, 2007 Share Posted January 17, 2007 Ive had it out 3 times now and all the o-rings are perfect. What happens is the oring on the injector sits in the groove in the rail.. when i fit the rail and tighten it in it weeps alittle at the manifold end... if i tighten it to much then the oring pull past the groove and it pisses out. What im wondering is if the boostlogic rail has i lip to stop the oring pulling past... then in that case i can tighten it down with out risking it pulling past. is it not possible to simply use a larger o-ring? i'm afraid that's about as technical as i get Quote Link to comment Share on other sites More sharing options...
michel lane Posted January 17, 2007 Share Posted January 17, 2007 i use this rail with dephi 1000cc injectors , i have had no problems with it. saying that how did you notice them weeping ?? Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 17, 2007 Author Share Posted January 17, 2007 i use this rail with dephi 1000cc injectors , i have had no problems with it. saying that how did you notice them weeping ?? I could smell fuel to start with... now im paranoid about it and always checking it. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 17, 2007 Author Share Posted January 17, 2007 All i really need to know is if the PHR or boostlogic rail have a lip in them to stop the injector pulling past the groove... then i can order one up. thanks:) Quote Link to comment Share on other sites More sharing options...
Chiefgroover Posted January 17, 2007 Share Posted January 17, 2007 PHR is good, but the mounting legs are usually too long, so a quick rub with the grinder will get the injector to head fitment airtight as I did. Fittings are good, if i can mange no leaks, so can you!. Quote Link to comment Share on other sites More sharing options...
TLicense Posted January 17, 2007 Share Posted January 17, 2007 I can confirm the PHR has no grooves at all. Quote Link to comment Share on other sites More sharing options...
TLicense Posted January 17, 2007 Share Posted January 17, 2007 Also, Dimitri mentioned that I should weld the collets onto the rail to prevent any leaks... Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 17, 2007 Author Share Posted January 17, 2007 I can confirm the PHR has no grooves at all. So i take it it has a lip that the injector pulls againt? Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 17, 2007 Author Share Posted January 17, 2007 Also, Dimitri mentioned that I should weld the collets onto the rail to prevent any leaks... Yea i was thinking that because it would stop it vibrating about. Quote Link to comment Share on other sites More sharing options...
