Baffle: boost logic 4" Borrow/Buy
Pig
After my car is done (approx beginning of march) i am going to need to use it for work to run the engine in. However, there is no way i can do this with a BL 4" exhaust.
Unless someone buys the exhaust i wont be able to afford a nice quiet one.
Does n e one have a baffle for sale? 2nd hand and new both considered OR does anyone fancy lending me one for a month?
Thanks
Jon
Don't think they make them, you're best off getting one custom made. I think turbofit have someone that can make these, they might even be able to do it if you just provide dimensions...
Pretty sure they do as terry once got me one in. Never got it/paid for it in the end though.
Im pretty sure mkivstore can get them too. Just a case of whats cheaper. Original or one being made up
Bud
Would a Blitz Nur spec fit... Ive got that in the garage, since Ive had it, never used it. Your welcome to it if it fits.
Si
Nope too small, thanks though.
i found that putting a buffle on mine limits the boost to 1 bar and the spool is pretty slow, ok for plodding around. Recently i mentioned this on the supraforums.com and a member suggested to use a magnaflow 4 inch resonator, this provides full flow but eliminates most of the noise created by the turbelance on the dp/mp. Its a section that is 12 inches long that would be welded to your exsisting exhaust system .According to various members it brings the noise level down considerably to around 92-100db from 120db. He informs me that if you put 2 units on and eliminate the rear bling box it should bring it down further. I have bought 1 unit and trying it out in 2 weeks.
On the otherhand if you are running bpu then the rear buffle is fine from terry.
Booslogic state this on thier site about the baffle
You can use this on long trips and take it out when you are ready to race. We recommend removing the silencer if you are planning on running more than 8-10psi of boost.
Only need it for work while running the engine in, so that should be fine.
Want to change it though, sick of the noise and i think it looks for too big on my stock car. possibly (dare i say it) chav!
