Muffleman Posted January 16, 2007 Share Posted January 16, 2007 Anyone know what thread size the bosch AF sensor is on the AEM UEGO wideband ? I have to tap one into a stock O2 bracket on my MR2. The 3" downpipe I have has a hole for one, but the sensor will foul on the rad pipe My tap and die set is no where near big enough, so I need to buy one - but not sure what size to buy. Cheers Matt Quote Link to comment Share on other sites More sharing options...
Jake Posted January 16, 2007 Share Posted January 16, 2007 I know it's the same thread as a NGK BCPR7ES spark plug 'cos that's what I used to blank mine off with Quote Link to comment Share on other sites More sharing options...
Muffleman Posted January 16, 2007 Author Share Posted January 16, 2007 Ah right, I have a spare plug or two - have to wander up to Halfrauds and size it up. Cheers Quote Link to comment Share on other sites More sharing options...
Muffleman Posted January 17, 2007 Author Share Posted January 17, 2007 Okay Halfrauds don't have a tap big enough, neither do the two other motor factors and tool shops I visited. Anyone know what size thread this is ? Going to have to order one online. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 17, 2007 Share Posted January 17, 2007 how about drilling a hole then getting someone to weld the right size nut on. Quote Link to comment Share on other sites More sharing options...
Muffleman Posted January 17, 2007 Author Share Posted January 17, 2007 Could do, but it would need to be done in situ, and the downpipe is between the cabin firewall and back of engine - a real bugger to get to. Or could take the DP off, but I lost enough skin, threw too many spanners round the garage and upset too many neighbours with my swearing when putting it on - so don't fancy taking it off The old sensor bracket is in my hand, so just need to tap the thread in and bolt to DP. Worth suggesting tho mate Quote Link to comment Share on other sites More sharing options...
cleland Posted January 17, 2007 Share Posted January 17, 2007 how about drilling a hole then getting someone to weld the right size nut on. Thats the way, and the nut you need is a M18x1.5 pitch i believe. Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 17, 2007 Share Posted January 17, 2007 Could do, but it would need to be done in situ, and the downpipe is between the cabin firewall and back of engine - a real bugger to get to. Or could take the DP off, but I lost enough skin, threw too many spanners round the garage and upset too many neighbours with my swearing when putting it on - so don't fancy taking it off The old sensor bracket is in my hand, so just need to tap the thread in and bolt to DP. Worth suggesting tho mate If you tapping a round bit of pipe i cant see the AF sensor sealing right when you screw it in... but i maybe wrong;) Quote Link to comment Share on other sites More sharing options...
Muffleman Posted January 17, 2007 Author Share Posted January 17, 2007 If you tapping a round bit of pipe i cant see the AF sensor sealing right when you screw it in... but i maybe wrong;) Nah I'm using the stock sensor mount, it is a bracket that I have gutted and can tap and screw the bosch sensor into This then mounts to the stock flange on the dp. Well I've found this http://www.driverstechnology.co.uk/spark-plugs.htm. I know the spark plug fits, as per Jake's reply, so it would seem as if it's a 14mm thread that I need. Getting there slowly Quote Link to comment Share on other sites More sharing options...
cleland Posted January 17, 2007 Share Posted January 17, 2007 I wouldnt be tapping no exhaust pipeing, jp is right wont work. Just find a local nut n bolt place and buy a bag of 10 for £2.00 and give 9 away like i do. Quote Link to comment Share on other sites More sharing options...
Muffleman Posted January 17, 2007 Author Share Posted January 17, 2007 In fact, not a bad little website that http://www.driverstechnology.co.uk/ Quote Link to comment Share on other sites More sharing options...
Muffleman Posted January 17, 2007 Author Share Posted January 17, 2007 I wouldnt be tapping no exhaust pipeing, jp is right wont work. Just find a local nut n bolt place and buy a bag of 10 for £2.00 and give 9 away like i do. Er, don't worry - I wouldn't tap into a dp. Said in the first post that it was to tap into a stock bracket. This is an MR2 downpipe, you can just see the stock flange at the top. A bracket bolts onto it and it's the bracket I'm tapping the bosch sensor into. The bracket and sensor can then be safely and securely attached into the flange. Quote Link to comment Share on other sites More sharing options...
cleland Posted January 17, 2007 Share Posted January 17, 2007 Got ya, simular to some bosses i had made, round bar drilled n tapped. Quote Link to comment Share on other sites More sharing options...
Muffleman Posted January 17, 2007 Author Share Posted January 17, 2007 That's exactly it mate. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 19, 2007 Share Posted January 19, 2007 If you have to buy an 18 mm X 1.5 tap you will prefer to buy a ready made o2 weld on, or a nut! Decent taps that size are EXPENSIVE! Quote Link to comment Share on other sites More sharing options...
steb9780 Posted January 19, 2007 Share Posted January 19, 2007 We might have one at work, if you're desperate. I am back in Sunday if you get desperate. It's a fine thread though, we tend to use course. You better have your weetabix tapping that size in steel. I do have some threadmilling cutters that are 1.5mm pitch but you probably won't have the machine to do it. Quote Link to comment Share on other sites More sharing options...
steb9780 Posted January 19, 2007 Share Posted January 19, 2007 Decent taps that size are EXPENSIVE! Chris is right even a small tap is expensive. Never mind a big one like this. Surely a ready made one isn't all that expensive. Quote Link to comment Share on other sites More sharing options...
Muffleman Posted January 19, 2007 Author Share Posted January 19, 2007 We might have one at work, if you're desperate. I am back in Sunday if you get desperate. It's a fine thread though, we tend to use course. You better have your weetabix tapping that size in steel. Thanks mate, will let you know - appreciated I have ordered a tap and it cost £15, but if it's the wrong size then I can send it back. I've ordered M14 x 1.25. Quote Link to comment Share on other sites More sharing options...
