SKI Posted June 15, 2004 Share Posted June 15, 2004 Just had bleed valve, TRL, RLTC and wheel aligment done by the master. My car absolutely flys.... Steady as she goes!!!! Said bye bye to a very new looking 911 Turbo on the way home, in the WET (with the obvious telling off from my passenger) At the next set of reds the Porsche guy "gesticulated" that I should lower my window, amid his gasps I heard him mutter the immortal words... "What the F.... have you done to that!" My reply of course was obvious.... This!!! Totally stock mate apart from the exhaust.... GUTTED!!! More rain inside his car than on my windscreen ha ha If you live up North and need a mod, Chris is da man!!! And it's all true....... His bathroom is huge Thanks Chris top job! Quote Link to comment Share on other sites More sharing options...
uncle kev Posted June 15, 2004 Share Posted June 15, 2004 When I bought my GTO TT it had a bleed valve on it and I was warned away from it as it was dangerous for the engine. Is this not the case with supe engines? ( please guys no pis taking about my weak mitsi engine:p ) Good job smoking the porka bud ! Quote Link to comment Share on other sites More sharing options...
SKI Posted June 15, 2004 Author Share Posted June 15, 2004 Good point... I think any boost upgrade has it's limitations. I'm only running about 1.15 bar so I think that's within tolerance for my UK spec, Chris felt strongly that my turbo's had been replaced for hybrids at some point due to their boost pattern, so I think I'm probably safer than some... I hope Quote Link to comment Share on other sites More sharing options...
Branners Posted June 15, 2004 Share Posted June 15, 2004 Bleed valves are generally okay on most engines, so long as you set them at a conservative level and have a boost guage fitted. You can set them for 16psi on a warm day and find yourself hitting 20psi on a cold day. A boost controller handles those changes better which is why most people go for them, but theres no reason not to use a bleed valve if its setup correctly. Chris has always been a fan of the simpler mods and has used bleed valves for a long time. JB Quote Link to comment Share on other sites More sharing options...
Jake Posted June 15, 2004 Share Posted June 15, 2004 Originally posted by SKI Just had bleed valve, TRL, RLTC and wheel aligment done by the master. What's a TRL ? Nice one with the Porsche BTW ! Quote Link to comment Share on other sites More sharing options...
CJ Posted June 15, 2004 Share Posted June 15, 2004 I would guess it's a TRL FCD. Quote Link to comment Share on other sites More sharing options...
LeeT Posted June 15, 2004 Share Posted June 15, 2004 Originally posted by CJ I would guess it's a TRL FCD. i believe the correct term is TRL VFCC:D . Quote Link to comment Share on other sites More sharing options...
CJ Posted June 15, 2004 Share Posted June 15, 2004 Clever clogs Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 15, 2004 Share Posted June 15, 2004 Thanks for the kind words Shane, glad I got it's little problems sorted to your satisfaction. Thanks for the work Quote Link to comment Share on other sites More sharing options...
