Sharpie Posted January 15, 2007 Share Posted January 15, 2007 Bit of a open question I know.... I came home tonight and someone followed me all the way home and told me that my rear wheel was wobbling around - Chrysler Grand Voyager. I got the bus up on the trolley jack and both rear wheels are firmly attached (wheel nuts) and I could not pull/push the wheel around. (I guess the handbrake does not help). Any Idea what could be causing this ? I'll be calling the dealer to get it booked in but, just thought if anyone had a clue ? Link to comment Share on other sites More sharing options...
RedM Posted January 15, 2007 Share Posted January 15, 2007 Not a wheel trim coming loose is it? Either that or wheel bearing. Link to comment Share on other sites More sharing options...
Sharpie Posted January 15, 2007 Author Share Posted January 15, 2007 No wheel trim, alloys on the bus. Link to comment Share on other sites More sharing options...
Pete Posted January 15, 2007 Share Posted January 15, 2007 Buckle? Link to comment Share on other sites More sharing options...
Ric Posted January 15, 2007 Share Posted January 15, 2007 yes buckle more than likley Link to comment Share on other sites More sharing options...
Chewie Posted January 15, 2007 Share Posted January 15, 2007 How did it feel to drive? Sure it wasn't a tyre side wall bulge? Has it been kerbed recently? Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted January 15, 2007 Share Posted January 15, 2007 sounds like a buckle... Link to comment Share on other sites More sharing options...
Sharpie Posted January 16, 2007 Author Share Posted January 16, 2007 Not curbed, feels fine to drive, all tyres are in good shape and psi correct. I followed the wife out this morning and drove ~2miles and it looked fine, it was down a straight road but, had a couple of roundabouts in it. Link to comment Share on other sites More sharing options...
keron Posted January 16, 2007 Share Posted January 16, 2007 best thing is to take it to a tyre/wheel dealer and put that wheel on a balancer machine to check it. should only cost you a fiver at most. at least it eliminates if the wheel is bucked or not? Also have you got sprigot rings on the alloys? if they are not standard wheels then you will need to use these if the center bore is a different size to stock, otherwise it could cause this probably. Link to comment Share on other sites More sharing options...
Sharpie Posted January 16, 2007 Author Share Posted January 16, 2007 Car and wheels are stock. Good idea about getting them checked out. Link to comment Share on other sites More sharing options...
garethr Posted January 16, 2007 Share Posted January 16, 2007 Swap the two rear wheels and see if the wobble changes sides? If it does, it's the wheel/tyre. If it doesn't, it's something else. Link to comment Share on other sites More sharing options...
Marco Posted January 16, 2007 Share Posted January 16, 2007 Long shot... Is the tyre dirty? If there's a bit of dried mud of the side of the tyre it looks like the wheel is wobbly when you drive. Link to comment Share on other sites More sharing options...
RICHARDA Posted January 16, 2007 Share Posted January 16, 2007 Thats what I would go with as you are only relying on someone elses info. Scuff or mud/dirt etc can look like a wheel wobbling especially at night in the headlights of the car following. Link to comment Share on other sites More sharing options...
Sharpie Posted January 16, 2007 Author Share Posted January 16, 2007 rubber is a little dirty with all this rain water - no blobs of mud or anyting.... but, last night I did put some tyre shine on the outside rubber walls....it would of made them look different compared to the rest of the tyre. Link to comment Share on other sites More sharing options...
Ian W Posted January 16, 2007 Share Posted January 16, 2007 as Garethr said, swap the tyres/wheels over (more than likely you'll have directional tyres so just see if you can borrow a pair of rears off a local member). Link to comment Share on other sites More sharing options...
Sharpie Posted January 16, 2007 Author Share Posted January 16, 2007 I don't feel any wobble, that's the thing! I have just been stoped by some lady saying she could see it wobble. It's not the soop [that's why I'm in non-soop section ]so, can't borrow a pair of rears off a local member and I don't have directional tyres Link to comment Share on other sites More sharing options...
Chewie Posted January 16, 2007 Share Posted January 16, 2007 Sounds more like this lady who followed you should've gone to Spec Savers. Link to comment Share on other sites More sharing options...
garethr Posted January 16, 2007 Share Posted January 16, 2007 I don't feel any wobble, that's the thing! I have just been stopped by some lady saying she could see it wobble. In that case, just get someone to follow you up the road. Probably just an optical illusion, but best to check. Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 19, 2007 Share Posted January 19, 2007 It's a Chrysler, the axle shafts probably coming out of the casing... Just kidding, it's probably her imagination if nothing feels as if it's falling off and the tyre hasn't a bulge in its sidewall. BTW, my camera is back and it's on charge, I will take pics for you shortly! Link to comment Share on other sites More sharing options...
