Voo51 Posted January 15, 2007 Share Posted January 15, 2007 Hey Can anyone help.... i would like to know if i had 19inch alloys would 8.5inch be wide enough for the front and 9inch for the back or do i definately need wider? also will 36 offset fir supra? Thanks:) Quote Link to comment Share on other sites More sharing options...
Voo51 Posted January 15, 2007 Author Share Posted January 15, 2007 also, on wheel width is the the measurment from the very outer edge to the other very outer edge or the inner edges where the tyre fits? if that makes sense?! Quote Link to comment Share on other sites More sharing options...
Jake Posted January 15, 2007 Share Posted January 15, 2007 would 8.5inch be wide enough for the front and 9inch for the back Yes that'll be fine. also, on wheel width is the the measurment from the very outer edge to the other very outer edge or the inner edges where the tyre fits? The inner part where the tyre sits : http://www.chris-longhurst.com/carbibles/images/xsection.gif Quote Link to comment Share on other sites More sharing options...
Sheefa Posted January 15, 2007 Share Posted January 15, 2007 I'm not sure Voo, but I have 17's with 9.5 on the back and 8.5 up front. Personally, I wouldn't go any lower than that at the rear and I'd be looking at 10" ideally. However, those with 19's will be able to clarify. You looking at SH wheels or new with rubber? Quote Link to comment Share on other sites More sharing options...
merckx Posted January 15, 2007 Share Posted January 15, 2007 245 's max on the front and 265's max on the rear will be good. It's not easy to say if a 36 offset wheel we be okay, you have to consider brake clearance which varies with wheel design. Especially so when you've got UK brakes like you do. Also rubbing on the arches. Are 265's wide enough on a 19" wheel which will give less traction - you're gone single too!!!!!! Quote Link to comment Share on other sites More sharing options...
Voo51 Posted January 15, 2007 Author Share Posted January 15, 2007 so is it from here to here..... Quote Link to comment Share on other sites More sharing options...
Jake Posted January 15, 2007 Share Posted January 15, 2007 No. See my earlier post Quote Link to comment Share on other sites More sharing options...
merckx Posted January 15, 2007 Share Posted January 15, 2007 That's 10" on the outside. I would think that's a 9" wheel. Quote Link to comment Share on other sites More sharing options...
Voo51 Posted January 15, 2007 Author Share Posted January 15, 2007 ok, its just iv had someone else tell me its the outer edge, grrrr!! so this wheel is defo no good for the rear? Quote Link to comment Share on other sites More sharing options...
merckx Posted January 15, 2007 Share Posted January 15, 2007 ok, its just iv had someone else tell me its the outer edge, grrrr!! so this wheel is defo no good for the rear? I'm not sure , is a 265 tyre wide enough for your car? Quote Link to comment Share on other sites More sharing options...
Voo51 Posted January 15, 2007 Author Share Posted January 15, 2007 well i currently have 18's on and the reara are 265/35/18. Quote Link to comment Share on other sites More sharing options...
Jake Posted January 15, 2007 Share Posted January 15, 2007 iv had someone else tell me its the outer edgeWell they're wrong. See the Matching your tyres to your wheels section on http://www.chris-longhurst.com/carbibles/tyre_bible.html Quote Link to comment Share on other sites More sharing options...
Voo51 Posted January 15, 2007 Author Share Posted January 15, 2007 apparently they had 245/35/19 tyres on them Quote Link to comment Share on other sites More sharing options...
Sheefa Posted January 15, 2007 Share Posted January 15, 2007 They look huge Voo. I would definitely want bigger tyres than 9's at the back, but as Jake said, check the fitment guide out. Quote Link to comment Share on other sites More sharing options...
Spoony Posted January 16, 2007 Share Posted January 16, 2007 hi dont go to small i have 9,5x19 et25 with 265/30/19 in the back and 8.5x19 et40 with 235/35/19 on the front. h&r springs with 35mm only had to lay down the edges in the back a little bit and it fits perfect take a look http://img183.imageshack.us/img183/6711/img3613800erta6.jpg 9x19 is not enought, the original j-spec wheels habe 9x16 and the eu spec has 9,5x17, both arround et50 9,5x19 et 25 is the same like 10,5x19 et50, only with smaller wheels, the et25 wheel is smaller but it has the samed distance to the edge like the et50 Quote Link to comment Share on other sites More sharing options...
NUTKIN Posted January 16, 2007 Share Posted January 16, 2007 Iv got 255-35-19 on the back of mine and im gona try get 265 on but i dont think they would fit its gona be close and iv got standard jspeck suspension but 255 is not wide enough really in the dry when the second turbo kicks in it losses traction in a straight line. My back rims are 9.5 wide JUST THOUGHT ID LET U KNOW Quote Link to comment Share on other sites More sharing options...
supra steveo Posted January 16, 2007 Share Posted January 16, 2007 just out of interest what wheels are they ? Quote Link to comment Share on other sites More sharing options...
NUTKIN Posted January 17, 2007 Share Posted January 17, 2007 If you mean me iv got FOX RS5 They have a mean deep dish on them the dish is chrome with silver wheel they look the nutz Quote Link to comment Share on other sites More sharing options...
