j-spec yellow billies?
richy2jz-gte
Yes it will all fit. I will warn you though that Dean, an old member here, did this to his UK Supra. A very low car and very hard ride will result, so don't be excpeting comfort or the ability to go over speed bumps at anything more than a crawl. :)
Apparently handled well with that setup though.
The black ones are the soft ones, the yellows the harder ones. Though even the black ones are harder than the export Supra suspension (UKs).
Softer rear suspension is better on launches, as it allows weight shifting to occur, the rear end squats when this happens, as you can see on some US Supras on drag suspension setups. :)
Mine came in from Jap with yellow shocks, but glancing at them the other day, it looked like they said Toyota on them.
Did Toyota do two different types of shocks then? Black, soft and yellow hard??
Mr Keef, I saw your motor, and thought you nicked mine.
Almost Identical, 'cept for the wheels. Although I think mine has a copy kit on it.
