De-cat
gooner
I'm looking for a better 0-60 time and its been suggested to BPU which from what I can gather is a full decat. My car at the moment has got a full stainless on it - how would I know if its got a cat in it? I don't want to sound like a twit here - but I'm kinda new to supras.:D
I am sure you could search, but depending if you are a uk spec or a j spec you will need:
decat pipe (uk or j spec -these differ slightly)
fcd (fuel cut defender)
restrictor ring (j spec)
boost controller (uk spec)
new fuel pump... walbro is mostly used....
oh and keep the stock airbox its better! (maybe pop a k+n flter panel in it)
the rest you can search. hope that helps
had a look and it has got the cat ...so ill need to get a decat ??
Has it still got both? There are 2 cats if you look at the pic I posted above, the small first one and the longer second one. The first one is the most restrictive of the 2.
Click on this link and read up on what you need. BPU.
i think its got bouth :rolleyes: .. ive got a ss on it and it joins up to the second cat. so i think i need bouth doing .. or should i just do the 1st
