Oil temp sensor
neil tt
Thank you, would it also be okay to put a T fitting into one of the oil feeds for the turbos, or is that just a really bad idea :)
I wouldn't do it personally, as you wouldn't want to risk a failure there... Also a lot of heat is generated by the turbo, so the reading wouldn't be 100% accurate...
