Pete Posted January 13, 2007 Share Posted January 13, 2007 I think I'm going mad. I'm positive last time I downloaded the Power Enterprise documentation it listed loads of little diagrams indicating which wires to use. I've since reformatted and lost that diagram. Now when I go to their JP site it just says I need wiring diagram TS-04 - but there's no diagram?! I've looked in each doc twice. The US site seems to be down so I can't look there either. I've just got some time to install the damn thing and now I don't know which wires I need. Does anyone have the original diagram around or can tell me which pins please please please? Quote Link to comment Share on other sites More sharing options...
Nic Posted January 13, 2007 Share Posted January 13, 2007 Pete there is a wiring diagram for the VVTi in these instruction, not sure if this is what you're needing.USDMCAMCON.pdf Quote Link to comment Share on other sites More sharing options...
Pete Posted January 13, 2007 Author Share Posted January 13, 2007 Thanks Nic. I got that one. (You mean page 10?) There was also one that actually gave the ECU pin outs for the Supra labelled as TS-04. I do have one RPM signal that other devices are tapped into, but I've no idea if it's in or out though. I've got pin out B4 (yellow) for O2 sensor (also B12 white), but I don't know if this is what they label as for the A/F signal? Cam pos sensor is on A12 (yellow), would that be vvti signal? I'm 100% sure they had a diag for the Supra on pages afterwards and they've been removed for some reason. I've emailed both US and JP... just a shame I can't do now its a relatively nice day. Quote Link to comment Share on other sites More sharing options...
Pete Posted January 16, 2007 Author Share Posted January 16, 2007 In usual fine manufacture support tradition, I've heard sweet F.A. from Power Enterprise. Anyone else help me out? Quote Link to comment Share on other sites More sharing options...
bondango Posted January 17, 2007 Share Posted January 17, 2007 Thanks Nic. I got that one. (You mean page 10?) There was also one that actually gave the ECU pin outs for the Supra labelled as TS-04. I do have one RPM signal that other devices are tapped into, but I've no idea if it's in or out though. I've got pin out B4 (yellow) for O2 sensor (also B12 white), but I don't know if this is what they label as for the A/F signal? Cam pos sensor is on A12 (yellow), would that be vvti signal? I'm 100% sure they had a diag for the Supra on pages afterwards and they've been removed for some reason. I've emailed both US and JP... just a shame I can't do now its a relatively nice day. Pete i take it you have the VVTi pinouts? I dont have them but i would use your current RPM signal. The 2 A/F signals you refer to, is one the Oxy sensor and the other the Sub oxy sensor? go for the normal and not sub oxy. You should have 2 pins on the ecu for VVTi?? One is OCV- which is VVti control signal return. The other is OCV+ which is VVTi Control signal - This is the one i would be using for the camcom. If i had the VVTi pinouts i could probably work it out using Another diagram or install guide on the net from a celica or matrix etc as reference. Quote Link to comment Share on other sites More sharing options...
Pete Posted January 17, 2007 Author Share Posted January 17, 2007 Pete i take it you have the VVTi pinouts? I dont have them but i would use your current RPM signal. The 2 A/F signals you refer to, is one the Oxy sensor and the other the Sub oxy sensor? go for the normal and not sub oxy. You should have 2 pins on the ecu for VVTi?? One is OCV- which is VVti control signal return. The other is OCV+ which is VVTi Control signal - This is the one i would be using for the camcom. If i had the VVTi pinouts i could probably work it out using Another diagram or install guide on the net from a celica or matrix etc as reference. I've got some pin outs from a diag uploaded on here a while back. I've had an email from the USA who are offering to send a diag. Let me see what that turns up with before I bother you any more. Thanks for the input. Quote Link to comment Share on other sites More sharing options...
Pete Posted January 17, 2007 Author Share Posted January 17, 2007 They sent them to me! Wheeeeee 20070117154231.pdf Quote Link to comment Share on other sites More sharing options...
spartan Posted June 27, 2008 Share Posted June 27, 2008 I found that complete file here (it's the last link on the page): Power Enterprise CAMCON Ti Although it's in Japanese, it does seem to confirm that the correct ECU wiring layout for the VVTi Supra is TO-04. Attached here too (just in case!) ... Quote Link to comment Share on other sites More sharing options...
spartan Posted June 27, 2008 Share Posted June 27, 2008 Did you get yours set-up and working Pete? I'm considering one but, despite the fact that it's referred to as 'plug-and-play', I can see that this would really take quite a bit of setting up to get the most out of it (not to mention the fitment of a wideband oxygen sensor and AFR gauge). Quote Link to comment Share on other sites More sharing options...
Nic Posted June 27, 2008 Share Posted June 27, 2008 (edited) Did you get yours set-up and working Pete? I'm considering one but, despite the fact that it's referred to as 'plug-and-play', I can see that this would really take quite a bit of setting up to get the most out of it (not to mention the fitment of a wideband oxygen sensor and AFR gauge). Dave, here are a couple of other similar products you may want to consider. GReddy V-Manage http://img99.imageshack.us/img99/6624/nengun116200trustgreddyyy1.jpg HKS Valcon Plus VCam Kit Pro http://www.hks-power.co.jp/products/engine/valcon/img/valconpro_image.jpg Edited July 13, 2008 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Pete Posted June 28, 2008 Author Share Posted June 28, 2008 I did get it working fine, but never got around to setting it up properly so took it out. It's yours for £150 delivered if you want it, boxed as new Quote Link to comment Share on other sites More sharing options...
Nic Posted June 28, 2008 Share Posted June 28, 2008 It's yours for £150 delivered if you want it, boxed as new *cough* Tech Section *cough Quote Link to comment Share on other sites More sharing options...
spartan Posted June 28, 2008 Share Posted June 28, 2008 I did get it working fine, but never got around to setting it up properly so took it out. It's yours for £150 delivered if you want it, boxed as new Thanks but I think I'll try to hold out for a bargain (like you got?) ... They do (very ocassionally) come up on oBoy (and point taken Nic ). Quote Link to comment Share on other sites More sharing options...
