Nic Posted March 15, 2007 Share Posted March 15, 2007 New Innovate DB AFR 52mm gauge kit, I've just ordered a blue one for my own car. http://www.innovatemotorsports.com/products/db.php Link to comment Share on other sites More sharing options...
Wez Posted March 15, 2007 Share Posted March 15, 2007 If the Defi sports cluster didnt look so cluttered it could be a nice bit of kit. I am tempted to try out the MXL AEM dash, couple of months till my bonus comes in Link to comment Share on other sites More sharing options...
bolarbag Posted March 28, 2007 Share Posted March 28, 2007 Yes I can supply, it is only available with Japanese software though at the moment AFAIK. How do you mean japanese software? i.e what? I have aem ems...non compatible? Link to comment Share on other sites More sharing options...
dangerous brain Posted March 28, 2007 Share Posted March 28, 2007 MXL Display for AEM systems The MXL family of displays and data loggers are plug and play compatible with all AEM engine management systems. The AEM system must have firmware version 1.19 or higher for it to recognize the MXL. The MXL connects to the AEM units via a serial RS-232 connection. With an MXL display or data logger plugged into your AEM system, you add a powerful, stunning display and data logger to your car. The MXL Strada is a dedicated street display, the MXL Pista and MXL Pro are racer-oriented data acquisition systems. http://www.aimsports.com/products/AEM-digital-display/index.html Its a tad expensive but methinks exactly what I have been looking for. I don't like millions of gauges all over the place and at the mo I have 5 which bugs me a bit. As I run an AEM ECU it would make sense to get rid of the HKS EGT,Boost,and Oil pressure and temp gauges and run them through this one gizmo. The wideband is a small gauge so I don't mind keeping that seperate. Link to comment Share on other sites More sharing options...
bondango Posted June 22, 2008 Share Posted June 22, 2008 Well just found a new setup, retails around the 400 mark. http://www.sigmaautomotive.com/gauge/drewtech/dashdaq.php Called the DashDAQ, its basically a OBDII display and scanner, Sat nav, and Can be configured for lots of ECU's and logging equipment such as the innovate stuff. Its touch screen aswell, with a good resolution. Support for Link, AEM to follow but lots supported at the moment Link to comment Share on other sites More sharing options...
wile e coyote Posted November 9, 2008 Share Posted November 9, 2008 New Innovate DB AFR 52mm gauge kit, I've just ordered a blue one for my own car. http://www.innovatemotorsports.com/products/db.php http://www.innovatemotorsports.com/products/images/DBkit_Dual_700.jpg I like look of these Link to comment Share on other sites More sharing options...
dangerous brain Posted March 2, 2010 Share Posted March 2, 2010 Well just found a new setup, retails around the 400 mark. http://www.sigmaautomotive.com/gauge/drewtech/dashdaq.php Called the DashDAQ, its basically a OBDII display and scanner, Sat nav, and Can be configured for lots of ECU's and logging equipment such as the innovate stuff. Its touch screen aswell, with a good resolution. Support for Link, AEM to follow but lots supported at the moment http://www.sigmaautomotive.com/gauge/drewtech/main2.jpg http://www.sigmaautomotive.com/gauge/drewtech/gauge03.gif http://www.sigmaautomotive.com/gauge/drewtech/gauge04.gif http://www.sigmaautomotive.com/gauge/drewtech/specs.jpg Does this one accept EGT, boost, and AFR sensor inputs then? Looks like the blurb says it does but for that money I'd want to know which sensors and wiring harness's I'd need Link to comment Share on other sites More sharing options...
