Blitz SBC Connections?
Tricky-Ricky
  • 3 months later...
Hi there
I'm doing the same stuff actualy. I want to use the id-3 for some temperature measurement.
First, some facts;
-There is no need tu buy the f*** expensive harness from blitz. You'll only need a fitting connector. Have a look to your favourite electronic discounter.
-The Pinout of the SBC id-3
http://supra.alonso.ch/d/222-1/67.jpg
You only need a fixed reference voltage (f.e. 5vdc) for the sensory supply. You can get them with a LM7805 component or similar. Then, you can use any fitting temperature sensor, NTC or PTC does'nt matter. Add a secundary resistor to limit the current. Connect the middle between the temperature sensor and the resistor to the input of the sbc, and set the parameters in the settings menu. F.e. 1VDC --> 10°C, 4VDC --> 90°C. Of course you have to calculate these values, but this should be an easy lesson for anyone with some electonic knowlegde.
I can post you my complete solution in a few weeks. There is some more important work to do first :innocent:
You hope you can understand my english :search:
Kind regards
  • 2 months later...
blitz sell a harness as far as i remember its only 30 stg :p connecting to 3 data connections with an output 0-16v etc water temp ,throttle , airflow ... try fensport for connector ..i fitted one before ;) easy as pie
Cheers matey :)
  • 4 weeks later...
  • 7 years later...
Guest nismo502
Sorry to bump up a very old thread. But have anyone got this working? How do you wire it up? What is your data settings for water temp sensors?
I tried to hook in a defi water sensor, 1 goes to ground the other goes to data2, not working.
