Any Peugeot 405 Diesel experts?
RobSheffield
Have a wierd one with my pug runabout :p
Car dies and it seems to be something to do with the clutch or gearbox.
Did it a week ago, but i had thought it ran out of diesel (dodgy guage now fixed!) so i primed the system charged the battery and tried again, started, problem solved thought i :)
Sadly, it just died again, and the only way to make it start is to push the gearlever hard into 1st and push the clutch hard down. It runs for 30 seconds then dies.
Any clues? I thought it could have been an earth strap nearby but wondered if i was missing anything?
sounds like a dodgy earth strap to me, but 405 are great cars i had 1 from new and done 257000 miles, serviced by my mate regular for beer:D only ever had the alternator changed, and obviously consumables, and it went all them miles on a funny coloured fuel;)
Engine starting and then dying kind of problems are usually to do with fuel supply, not gearbox/clutch.
A common fault can be:
Blocked fuel filter (not likely to stop it idling. More likely to stop it reaching max power)
Air getting into the fuel supply lines (loose connector?)
The stop solenoid on the back of the pump failing.
The most common is the stop solenoid. It fails by opening slightly when the ignition is first turned on, but then closes again as the coil that holds the plunger open is knackered, stopping the engine.
Air in the fuel system is the second most likely. Have you tried pumping the hand priming bulb while its running?
No idea why the clutch would cause it to stall!
I have no idea either mate!
I had thoght maybe a actuating arm was interfering with some cabling but i checked and it isnt.
A friend of mine suggested they are known for fuel pump problems. I am looking into that today.
I have primed/bled the system a few times now, each time a little air is expelled.
I know the stop valve was replaced once, i am thinking of purchasing a new one and seeing how it goes.
I wonder if motor factors supply these, or if its a dealer only item.
